Hi Team - Suppose I recorded an old TV show in standard definition and then recorded it again later on in HD. I would like to have both versions available at the same time within Plex.
My question is how in Plex, can you differentiate the shows so that they can both be available at the same time?
Couldnt they be stored together.
Most clients I use offer the âplay versionâ option.
Granted I dont recall it it offers resolution in the choice but I assume the bitrate would give it away as to which is which?
Then youâll have to select a version every time you want to start an episode.
With my approcach, you only have to press play on the right showâs poster and can binge on it.
