Is there anyway to make the searches on channels work?, like type the name of a movie and get it from a channel?
Look at UAS in my signature its full of channels you can search.
I didn't understand, I already have the UAS, the thing is, for example, I go to the Anime HD channel and there's a "Search" option, when I go there, I get an error, something like it's not available, all channels say that.
For example, I go to a movies channel and I want to look for the Spiderman 1 movie, when I press search on my Apple TV3, I get an error.
Thank you for your answer.
Channel search is a little picky. A couple of more std. channel should work, though.
If you experience issues, please post more detailed info plus a PlexConnect log.
I just did a quick check. Two channels wherein search has worked regularly in the past are Twitch and SSPlex. Now when you select search in these channels you do not even get the search interface. Based on when last I used search in Twitch I think this is a result of changes made in Plexconnect over the last month or so.
