When no source is found, video / music / pictures sections disappear
Hello there,I´m using pmc under Ubuntu 11.10 and when no source is detected you can´t access video / music / pictures sections.
This is bad because if I need to reach an external source I can´t, as I can set up the source only in there (am I right?).
Anyway I can´t play videos from external sources, it just loads for a couple of seconds then stays on the movies page. If I set up vlc as an external player it works in the external player.
Hope this helps you guys, thank you very much!
Best
Gia
