I have my screensaver set to come on every 15 mins and display library art. The effect is nice and I like it but the clock (which I also really want to have on my screensaver) is displayed right over the name of the art source making them both hard to read. Any way to fix this?
If nobody knows how to fix this, can someone point me to where it is in the code?
(Not an OpenPHT developer) I’ve never seen this. The relevant code is here: https://github.com/RasPlex/OpenPHT/blob/openpht-1.8/plex/GUI/GUIPlexScreenSaverPhoto.cpp
Thanks man. I will check it out. This is what I am seeing btw:
Opened an issue in Github: https://github.com/RasPlex/OpenPHT/issues/257
I think it’s important to tell in your error description wich resolution you use. Try different resolutions to check if the behavior changes.
@Violetto said:
I think it’s important to tell in your error description which resolution you use. Try different resolutions to check if the behavior changes.
You are absolutely correct. This only occurs at the 4K resolution setting.
