Serenity for Android 1.6.0-M1
This version adds support for playing back Trailers for your movies or previews for your Episodes. The support is only currently working in detail view, and you must have the official youtube app installed on the device in order to playback the trailers. The trailers are based on the metadata information from your Plex Media Server.
I'm still working on how best to support this and subtitles in grid view.
https://github.com/NineWorlds/serenity-android/wiki/Downloads#160-m1-available
Download: http://nineworlds.github.com/serenity-android/downloads/Serenity-1.6.0-M2.apk
- Trailer support in Grid View for Movies.
- Cache trailer metadata for faster browsing in subsequent sessions.
- Subtitle Indicator for Grid View.
- Subtitle selection option through context menu in Grid View.
- Improved German language translation (user provided translation)
Data is now cached from Youtube when retrieving trailers. In grid view the first time browsing may be slowed down but, future sessions should use the cached data and be fast.
Unfortunately that link leads to a 404 error page, both as the link is posted here and as it is posted on the page linked to by your previous release post.
So at present it's not possible to download the '1.6.0-M2' version through either of those links.
Best regards: dlanor
Thanks. I forgot to actually push the binary to the download site. Should be working now.
Yes, now it works fine.
Thanks for the quick response!
1.6.0-M3 is available.
Download: http://nineworlds.github.com/serenity-android/downloads/Serenity-1.6.0-M3.apk
- Fix Force Close when using Queue and Grid View.
- Add Details context menu when in Grid view for videos.
- Add Subtitle selection to Grid view in Seasons episode selection.
- Add Trailer selection to Grid view in Seasons episode selection.
- Updated How to Contribute readme section.
1.6.0-M5 is available:
Download: http://nineworlds.github.com/serenity-android/downloads/Serenity-1.6.0-M5.apk
- Add preference setting whether TV Shows previews are searched for on YouTube. Disabled by default.
- Fix force close on XLarge displays in Grid View.
If you have used prior versions of 1.6.0, you may want to Clear the apps data to reset the internal SQL database used for caching youtube content.
Crashes upon launch in Android 4.4.2
Any chance you can grab a logcat. That should have the cause. I do have a 1.6.1 build I need to put up which takes care of some other issues. Will try and post that tonight for the development version.
Update: Here is the link to the 1.6.1 build.
https://github.com/NineWorlds/serenity-android/wiki/Downloads#wiki-161-m1-available
That build works just fine! :)
