Is user
plexthe admin/default/account-used-to-install-Ubuntu ?
Yes that’s the only user
Is user
Damn,
Now I know why it’s all frogged up.
Ubuntu NEVER works well this way.
All the OS-isms interfere.
Easiest solution is to move PMS to a new username and then add that username to group video.
It involves:
chown -R Thoughts?
sounds good, I could keep that “legacy-plex” user for the docker instances while using “new-plex” user for PMS only. My video folders are mounted over NFS where I remap any user to a specific one so it won’t blow up if I change the owner of PMS
What I’m thinking (on the fly here)
plex because it’s your “Plex server”pms to run “Plex Media Server”with one hopefully less cranky than the other ![]()
yeah pms sounds good, gonna admit that the first idea that came to my mind was legitplex but it’s obnoxious on a second thought ![]()
Your humor is warped. I like it
lol
Please find for me which nologin ?
Please find for me
which nologin?
/usr/sbin/nologin
PMS is stopped ?
when I’ve typed the which command? : no, same result if pms is stopped.
Else I’ve just stopped pms rn
Here we go:
(Let me proof read this again after I post. I don’t want any errors)
AS ROOT (sudo bash)
systemctl stop plexmediaserver
ps -ef | grep -i plex
## Make sure NO plex processes remain. Kill if needed
# Create new user
useradd --system --shell /usr/sbin/nologin --home /var/lib/plexmediaserver "pms"
groupadd --system "pms"
usermod -g pms pms
# Add 'video' group to pms (we know by inspection)
usermod -a -G video pms
# Confirm (should see 'pms video')
groups pms
# now change ownership of all /var/lib/plexmediaserver
chown -R pms.pms /var/lib/plexmediaserver
# Create override for pms
mkdir /etc/systemd/system/plexmediaserver.service.d
cat > /etc/systemd/system/plexmediaserver.service.d/override.conf <<EOF
[Service]
User=pms
Group=pms
EOF
# You can pretty ^^ this up in a text editor if you want but we only
# need change the username to 'pms:pms'
systemctl daemon-reload
# Systemctl should now recognize the 'override.conf' file
systemctl status plexmediaserver
# Let's start it.
systemctl start plexmediaserver
I’ve written the above so you can copy/paste to the terminal command line
# is obviously comment / info for you.
If there are any deviations…STOP
Stop before you systemctl start plexmediaserver
You can change any file permissions
(do one if needed as confirmation – perhaps “Other Videos” so we can test using the test files )
Ready ?
Ready ?
gonna stop if something isn’t expected after each command
Making progress ?
so
# Create new user
usermod -g pms pms
got some warning telling me that the group already exist with pms user in it, certainly the previous command auto-create/add new pms group while creating the user. I’ve checked the group and user and it was pms:pms so i continued
groups pms
[Service]
User=pms
Group=pms
EOF
additionally called cat /etc/systemd/system/plexmediaserver.service.d/override.conf just to double check
and I stopped there, I think I should change the user in autofs conf before starting pms:
On Ubuntu 22, you will get the warning about adding pms to group pms
(I forgot that – SORRY)
If you’re mounting NFS, Why are you doing it that way?
I do it this way: (sec=sys option)
# Master Media mount
192.168.0.20:/vol/media /glock/media nfs defaults,sec=sys,rw,auto,async,x-systemd.after=network-online.target,nofail,bg 0 0
– Mounted with sec=sys option so the NFS server changes to UID/GID permissions in the mounted filesystem
– On the server side,
— Dir = 0755 (everyone can read)
— File = 0644 (everyone can read)
Now, local PMS user can READ the NFS link without any fuss.
If you want to keep it your way, for now == ![]()
The basic test is confirm PMS starts and Media shows as (maybe?) unavailable
good point on NAS side I’m already in security=sys, my autofs conf on server side is maybe too legacy ![]()
starting pms rn
It’s alive ![]()
Libraries got the stuff at the right place and I can start a movie like nothing happened.
Should I redo the LG video watch then?
Play one of my videos in Plex/web for 30 seconds.
Stop Playback.
Download the Logs zip file
Attach.
Review time
Ok so for the LG file, 2nd pass:
Plex webapp (local):
more or less the same experience as the previous test
logs:
Plex Media Server Logs_2022-12-18_04-24-53.zip (271.9 KB)
