def TestIt():
Log("TestIt called")
return "Success!"
My channel code (which calls the shared code, using the SharedCodeService) goes in MythRecordings.Bundle/Contents/Code/__init__.py:
import xml.etree.ElementTree as ET TestIt = SharedCodeService.plexmythlib.TestIt def Start(): TestIt()
And finally, my serach service goes in MythRecordings.Bundle/Contents/Services/Shared Code/plexmythlib.pys:
def Search(query):
Log("Search service!")
oc = ObjectContainer(title1='Myth Search service results', title2='Search Results')
return oc
This works great! Looking in the plugin log file, I see
... 2015-02-26 20:25:27,762 (7fb64f093740) : INFO (plexmythlib:14) - TestIt called ...
So at this point I can conclude that the shared code is located and registered correctly (I won't bore you with the details - it's all boilerplate).
HOWEVER, as soon as I update the shared code to reference xml.etree.ElementTree:
def TestIt():
return "Success!"
everything fails miserably - the log now goes:
... 2015-02-26 20:40:30,933 (7f11fffff700) : DEBUG (services:362) - Loaded services 2015-02-26 20:40:30,939 (7f11ff7fe700) : DEBUG (services:433) - Loading 1 shared code modules 2015-02-26 20:40:30,945 (7f11ff7fe700) : CRITICAL (services:441) - Error loading shared code (most recent call last): File "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/services.py", line 435, in _setup_shared_code_sandbox sandbox.execute(code) File "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/code/sandbox.py", line 256, in execute exec(code) in self.environment File "", line 1, in File "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/code/sandbox.py", line 333, in __import__ return mod.load_module(_name) File "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/code/sandbox.py", line 44, in load_module module = RestrictedModule(name, path, sandbox) File "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/code/loader.py", line 30, in __init__ exec(code) in self.__dict__ File "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/MythRecordings.bundle/Contents/Services/Shared Code/plexmythlib.pys", line 6, in import xml.etree.ElementTree as ET AttributeError: 'module' object has no attribute 'etree' ...
I can reference and use this library perfectly well from my main channel code (__init__.py), so it's in the Plex framework somewhere - may shared code just cannot see it.
Can someone tell me how I give the shared code access to the same modules as my __init__.py has?
PS: My apologies if this is common Python/Plex knowledge - I'm learning as I code....
