Site Config for Silverlight content
Hi!
I’m trying to build my first plugin for Plex, but… how do I reference a Silverlight player/content?
I know from the wiki and the forum that a Site Config for Flash based content looks like this:
<site site="http://www.example.com"<br />
	plugin="http://www.example.com/player.swf"<br />
	initialState="playing"<br />
	version="1.0"><br />
</site>
But a Silverlight media player isn't really one file you can point to. In my case, the page containing the Silverlight player looks something like this:
<div name="mediaspace" id="mediaspace"></div><br />
<script type='text/javascript' src="silverlight.js"></script><br />
<script type='text/javascript' src="wmvplayer.js"></script><br />
<br />
<script type="text/javascript"><br />
var cnt = document.getElementById("mediaspace");<br />
var src = 'wmvplayer.xaml';<br />
var cfg = {<br />
    file:'http://www.garnierstreamingmedia.com/asx/StreamerSwitch_new.asp?sl=1&stream=134',<br />
    autostart:'true',<br />
    image:'',<br />
    height:'596',<br />
    width:'768'<br />
};<br />
var ply = new jeroenwijering.Player(cnt,src,cfg);<br />
</script>
Pointing the Site Config to the *wmvplayer.xaml* file (which is the 'description' file for the Silverlight media player) doesn't work.
<site site="http://www.example.com" <br />
	plugin="http://www.example.com/wmvplayer.xaml"<br />
</site>
Any suggestions?
I think (but may be wrong) that you just have to use plugin=“silverlight” for Silverlight players :slight_smile:
Thanks Jam! Works perfect!
But my next problem is this: I can’t control the audio volume of the stream. If I press + or - on my Apple remote I see the volume indicator go up or down, but the volume doesn’t change. Is this a known problem, or do I have to add something to my Site Config to control the volume?
The same happens with FLASH content
The VOLUME of ANY other content is controllable by pressing + or - on the Apple remote.
I was told this is a DESIGN issue not a "BUG".
