Plex is installed on an NAS which seems unable to fix the file directly so I’m having to transfer the db file to a desktop computer that doesn’t have plex installed to try and fix the file from there.
What might be the solution is to install Plex Server on the desktop (without running) so I can access the sql repair file
Right, finally got the longer sql to execute on the file but only seemed to take it down about 1mb and I ran the test query and results are the same, still got one file with over 1m extras.
As an alternative is there a way to purge all records of that file inc extras, titles and things. If there is I can go through each record with high extras move the file, purge the record and then put the file back. Doing it that way it could potentially just shrink the database as the records are gone and then refresh metadata properly once the file is replaced as it will re download the data. Longwinded way round but main one is the 1m extras one.
Yep, you got it, I didn’t even see step 2 but I’ve now run all commands (eliminated all others on my list as well). Database has now gone from 3.4gb to around 350mb and does seem to be running faster now.
