Server Version#: 1.16.2.1321
Player Version#: (LG) 2.1.0
I had moved over to x-play (and this still works) but I really wanted the native app, well I had issues with buffering for HDR 4K content even in direct play with no transcoding.
Well I did a bit of googling, and it seems that this:
fixes the problem of buffering perfectly. I have a strong 1000mps connection on my switch and I have played my highest bitrate movies (over 90mbit) with absolutely no issues - furthermore you can skip/scan sections and it’s almost instantaneous.
This works on my LG tv, but I don’t see why it wouldn’t work on any other tv with a USB connection.
Why oh why are tvs only fitted with 100mbps LAN sockets, I don’t know.
Anyway, x-play, plex, now stream 4k content with HDR processing beautifully.
Whilst wifi is great for mobile devices, I’m still not a fan, so I’m happy I was able to find a solution.
Important to note that the tv doesn’t “see” the connection in the menu, so it says wifi/lan disconnected, but it absolutely works.
I’m sure this topic has been covered before, but I wanted to share my experience and say it absolutely fixed my problem, for £10 it’s worth it.
