Are there Application Event log exceptions as you have pasted, for each of these failure times?
Feb 14, 2019 14:05:32.393 [2724] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe' exit code for process 5008 is 255 (failure)
Feb 14, 2019 14:06:34.268 [2724] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe' exit code for process 2596 is 255 (failure)
Feb 14, 2019 14:07:14.873 [4148] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe' exit code for process 4176 is 255 (failure)
Feb 14, 2019 14:07:40.414 [4148] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe' exit code for process 120 is 255 (failure)
Feb 14, 2019 14:09:02.644 [4148] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe' exit code for process 3484 is 255 (failure)
Feb 14, 2019 14:11:12.040 [3416] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe' exit code for process 652 is 255 (failure)
Feb 14, 2019 14:12:00.952 [2340] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe' exit code for process 4696 is 255 (failure)
Feb 14, 2019 14:12:24.744 [2340] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe' exit code for process 2700 is 255 (failure)
No, i havent got around to that yet. these errors are from numerous DVD rips - itās not one movie that cuases this, but any type, as far as I can see, of mpeg-based media.
ill go find somrthing now to make a clip out of any of them - bear with meā¦
Hi sorry i had not gotten the chance but i tried to do it again and it seems that the server on the PC no longer plays the trailer also.
It seems that when it was a fresh install on the PC and then i added the files it started working. Once i placed the backup from my synology with all the metadata and all other files it stopped working.
Hi, I started getting this error on remote devices a few days ago, and I have no idea why or what changed. Only things that come to mind is monthly windows updates, or graphics driver update (nvidia rtx2070). Happens on amazon fire 4k, windows 10 and xbox one clients, all using the provided plex apps. If switched to direct play, if possible, works without any problems. Log package provided via PM.
Well the errors you are getting are ones previously came with a windows update in July 2018 and Microsoft corrected it with a further update on 16th july 2018. I have mentioned this before that may be microsoft re-introduced the problem recently.
Could you tell me which windows update you suspect?
The errors are always the same failure to read a manifest or segment list and followed by an av_interleaved error
Feb 20, 2019 20:54:53.689 [2824] ERROR - [Transcoder] [segment @ 0386aec0] Failed to open segment list 'http://127.0.0.1:32400/video/:/transcode/session/xax8cabxoj18k3erh8vlyds4/19e71e90-0693-4f81-8642-690c732e183e/seglist'
Feb 20, 2019 20:54:53.693 [1432] ERROR - [Transcoder] av_interleaved_write_frame(): Unknown error
Feb 20, 2019 20:54:53.698 [7920] ERROR - [Transcoder] Error writing trailer of chunk-%05d: Invalid argument
iād suspect the february monthly update rollup for windows 10 (https://support.microsoft.com/en-us/help/4487044/windows-10-update-kb4487044), would be the only one that comes to mind and the timeframe would fit (i installed it on 13th of february). i suspect i didnāt notice the problems earlier as most files are played through direct play from my server.
