SOLUTION: Conversion failed. The transcoder exited due to an error
It is showing some invalid data coming in for the requests sent out to get the trailers played back
Aug 13, 2018 11:26:20.556 [15589] ERROR - [Transcoder] http://127.0.0.1:32400/services/iva/assets/537718/video.mp4?bitrate=2500&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Invalid data found when processing input
Aug 13, 2018 11:26:52.088 [15588] ERROR - [Transcoder] http://127.0.0.1:32400/services/iva/assets/537718/video.mp4?bitrate=2500&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Invalid data found when processing input
Aug 13, 2018 13:20:12.687 [16227] ERROR - [Transcoder] http://127.0.0.1:32400/services/iva/assets/537718/video.mp4?bitrate=2500&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Invalid data found when processing input
Aug 13, 2018 13:20:42.378 [20614] ERROR - [Transcoder] http://127.0.0.1:32400/services/iva/assets/537718/video.mp4?bitrate=2500&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Invalid data found when processing input
Aug 13, 2018 13:26:20.144 [21028] ERROR - [Transcoder] http://127.0.0.1:32400/services/iva/assets/537718/video.mp4?bitrate=2500&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Invalid data found when processing input
Aug 13, 2018 13:27:21.465 [21465] ERROR - [Transcoder] http://127.0.0.1:32400/services/iva/assets/599616/video.mp4?bitrate=2500&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Invalid data found when processing input
Aug 13, 2018 13:27:56.272 [21497] ERROR - [Transcoder] http://127.0.0.1:32400/services/iva/assets/587139/video.mp4?bitrate=2500&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Invalid data found when processing input
Aug 13, 2018 13:30:43.026 [21888] ERROR - [Transcoder] http://127.0.0.1:32400/services/iva/assets/636685/video.mp4?bitrate=2500&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Invalid data found when processing input
Do you have any firewall restrictions ? blocks in place ? any proxy ?
Yoou could get a wireshark capture and send me by provate message zip of the pcap file and logs to see if there are any clues
I have explained in several posts above that the transcoder may fail due to lots of different reasons. There is not an issue that is common. The only exception being the windows update bug that affected hundreds of users since July 10th.
Please provide logs for your problem and i will have a look
See
https://support.plex.tv/articles/201643703-reporting-issues-with-plex-media-server/
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
Without logs issues cannot be investigated
If the same underlying error is occurring on windows 7 as was seen for the windows 10 update bug, then may be there was a similar update to windows 7 - but need logs to know why the transcoder is failing.
See
This looks similar to the problem introduced by Windows 10 Update (July 10th Update) - and subsequently fixed by the 16th July update
Aug 14, 2018 21:40:41.048 [9552] ERROR - [Transcoder] [dash @ 024ba9c0] Unable to open http://127.0.0.1:32400/video/:/transcode/session/7q7floeh43mned7vlh1rx1le/8adc9790-5b64-4cc5-8e5b-2b208fef95e4/manifest for writing
Aug 14, 2018 21:40:41.063 [13732] ERROR - [Transcoder] av_interleaved_write_frame(): Unknown error
See [Windows 10 Update KB4338819 issue] Conversion Failed. The transcoder exited due to an error and the solution linked to the first post
You will need to check for updates and may need a number of restarts to pick the later windows updates
Details on that forum thread
The issue here is because it is a crash of the transcoder process rather than a tidy exit with a reported error. Unfortunately we need to see what the transcoder logged before it crashed to see if there are clues to the problem
There are improvements coming along for the logging
Thank you, nice to hear from you.
A few fresh installs, trailers and extras were playing. I have no possible clue how that happened, I was monitoring every change, but nothing explains how it resolved.
Yes ! you are right, I am using Socks 5 proxy with an app ShadowSocks
I need to use it because my ISP blocks various sites here including Plex Metadata downloads painfully slow. Due to that I have been using socks 5 proxy
I have 2 other Plex servers on my Window and MacBook and they seem to cope up well with the proxy and never I got a single problem from them
The device I was having issues with is my NVIDIA Shield TV. The server on it is creating various issues for me. And I have done about a dozen clean installs and each install would unveil a new problem.
Some issues are below
  1. The Plex setup on Nvidia Shield Tv is not able to perform well with Proxy/VPN, when I am using Wifi under Proxy, the server shows as “Running”, when I switch to Ethernet, it shows as “Stopped”, regardless of restarts of shield tv, or manually clicking “start”, the server wont start, until I turn the Proxy OFF. But dispite it shows off, its still running at times and discoverable on other devices.
    Something to mention, the Proxy has LAN Bypassed.
  2. Plex Server on Shield tv runs painfully slow. I experienced this in some installs, it was really very slow. Loading up “On Deck” and other items including Movies and TV Shows sometimes took, 5-10 or upto 15 seconds. Sometimes didnt even load up and needed to force close.
    But when did some reinstalls it would make it comparatively faster only to show some new problems.
  3. Dolby Atmos never seemed to work for me. DTS MA and DTS X seem to work right off the bat. As soon as I play DTS file, the player downloads some update and starts playing directly.
    But for Atmos, it doesn’t download anything and just resorts to transcoding and ultimately fails (maybe because its a 4K remux movie)
    Same Atmos file plays instantly on Kodi and Plex Add-on for Kodi as well.
    My Plex is set to Passthrough to Auto
Now, im not sure how to offer you the Wireshark results from Shield TV, incase if you still need them. If you do, I`m willing to provide you any thing you need to solve the issues.
FYI
Shield TV Firmware : 7.0.2
PMS : 1.13.5.5291 (smb)
Plex Player : 7.3.2.6276
Please raise issues as separate topics with appropriate forum topic tltles and tags
Would like for this thread to remain specifically for The Transcoder exited due to an error
sa2000, thank you. The problem has been resolved and was a permissions problem where the codex was attempting to execute.
not a paying customer, but one that referred a lot of customer as I used to love how it used to work…I been trying for weeks now to solve this issue and it remains the same…bye plex T-T
There isn’t a magic wand to fix issues without looking at diagnostics and logs to see what the issue is
The most prevalent cause of the trancoder failure came in 10th July 2018 when Microsoft released a faulty Windows 10 update. They fixed the issue on 16th July but the bad update is still one of a series of updates that are available and users hit the problem if they apply it and do not restart and do further checks for windows updates after that
It may well be your problem - details on this topic
Hello @sa2000,
I just got this error too… I watched a movie earlier and it was fine, and then it started on another movie. Running PMS on Ubuntu/16.04.5 and ATV Client.
Logs:
Plex Media Server Logs_2018-08-16_22-43-38.zip (4.0 MB)
I been having the same issue, with movies I know worked prior to several updates ago, anyways, this is getting really annoying, i have since moved to watching things on my PC with a media player instead until this gets fixed.
It doesn’t seem to matter if its an older video file or newer, either way the videos are refusing to play.
Spot on guys! This update is a disaster for the transcoder. I’ve removed it manually from the command line & the problem has completely gone away! You can use this in a batch file or from the CMD window:
wusa /uninstall /kb:4338819 /norestart /quiet
Then restart the PC. May pay to check it every update/restart with ‘wmic qfe list’ command & if the crapware is back just uninstall again, rinse, repeat.
Yes Microshaft, we shouldn’t have to be doing this because if your lack of care factor, GRRRrrrrr!@#$%^&*()
Couple things I want to inform you of. First, the method that you showed to remove the update was already posted with a disclaimer. That is a security update which patched memory access holes in Windows. Second, you no longer need to remove that update as there were two later updates, in particular the one on the 16th of July, that solved it. And lastly, you should (I implore you to) reinstall that update and the following three that are after it.
See these posts in the Windows 10 specific thread:
and
If you continue to have problems with Plex after installing, please make sure you system is completely updated. The most current stable version of Windows is 1803, build 17134.228.
I am also having the same problem. Please fix ASAP PLEX.
I have also begun experiencing a “Conversion failed. The transcoder exited due to an error” problem in the last few weeks on the BBC iPlayer channel. The iPlayer had been working fine for months. I tried to remove/reinstall the channel, but that didn’t help. My PMS is the latest version (1.13.5.5291) on Ubuntu 16.04.4 LTS. Logs attached.
Plex Media Server Logs_2018-08-20_12-37-50.zip (3.6 MB)
Been having this issue with PMP. weird cuz it’ll work fine for hours, then when the first error happens and I try to resume playback, it happens like every minute indefinitely. No idea what makes it stop again but eventually it does. I have all the latest windows updates too.
I am having the same problem trying to watch a .mkv file with TrueHD 7.1 audio. Server is on Windows 10 with both windows 10 and the server running the latest update. Been trying most of the fixes and still couldn’t find a solution. Moved transcoder file to another directory but the issue keeps persisting.
Well the error is generic and could be due to many different reasons
In your case, it appears to be relating to the EasyAudioEncoder
The encoder process was started at
Aug 16, 2018 21:52:10.019 [0x7f48bb3fe700] DEBUG - Job running: '/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/EasyAudioEncoder-141-linux-ubuntu-x86_64/EasyAudioEncoder/EasyAudioEncoder'
Aug 16, 2018 21:52:10.020 [0x7f48bb3fe700] DEBUG - Jobs: Starting child process with pid 2994
After that a Transcoder process was started and it failed to get data from the EasyAudioEncoder process and ended with transcoder failure
Aug 16, 2018 22:28:08.375 [0x7f48c4bff700] ERROR - [Transcoder] [truehd_eae @ 0x2a32040] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-b247625c-d726-4b79-a581-cb921f940bb9/EasyAudioEncoder/Convert to WAV (to 8ch or less)/85600B8F-9A06-4E86-93EB-6D3508875994_2995-0-5345.wav'
Aug 16, 2018 22:29:26.000 [0x7f48a6ffe700] ERROR - [Transcoder] [eac3_eae @ 0x30f0f40] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-b247625c-d726-4b79-a581-cb921f940bb9/EasyAudioEncoder/Convert to Dolby Digital Plus (Max Quality - 1024 kbps)/85600B8F-9A06-4E86-93EB-6D3508875994_2995-1-4083.ec3'
Aug 16, 2018 22:30:20.206 [0x7f48c9bff700] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 2995 is 1 (failure)
121496 Aug 16, 2018 22:30:20.383 [0x7f48b13f8700] DEBUG - Signalling job ID 2995 with 9
The EasyAudioEncoder binary is here
and you must make sure that if this a mounted volume that you do have exec set and you do not have noexec
The other aspects to check are for this path
The path must be local and not a network drive as it needs to support iNotify notifications of changes
As mentioned many times the Transcoder error message is a generic error message and unless one looks at logs you cannot say your problem is the same as someone else’s
Do you have logs of the failure?
Point me to a post where you have uploaded logs
If not, See
