Solved: Localhost not respecting home screen setup
Server Version#: 1.21.1.3830
Not sure if I am doing something wrong or the system is just not designed to to what I want.
I have a library as Other Videos and it has ~80 videos in it with the last one being added on 12/31/2020.
On the home screen on the server (http(s)://localhost:32400/web/index.htms#) I did an edit of the home screen using the pencil at the top right of the screen. The screen was changed from Manage Home Automatically to manual edit. I ordered the content in the order I wanted to see them and included Other Video. I removed the items I did not want to see on the home screen and saved.
When I go to the home screen, the items are ordered the way I assigned them, and the items I deleted are not on the home screen, but the Other Video is not on the home screen. The library does have content it in.
I tried to set it back to manage automatically but that did not do anything. I tried to set it back again to manual and redid my setup but still no Other Video.
This is my home screen setup now:
Continue Watching - Media Server
On Deck - Media Server
Recently Added Movies - Media Sever
Recently Added TV - Media Server
Recently Added Videos - Media Server
Recently Added Music - Media Server
On Deck - Podcasts
Recommended - Podcasts
The home screen shows everything the correct order but still is missing the Recently Added Videos.
Am I doing something incorrect? Anyone else have this issue?
Michael
Will mark as solved.
As I was reading the thread on setting up the new beta Plex TV Scanner, I saw the step where you have to reset the Visability on the library. I had done this but tried it again after resetting the homescreen to manual edit. I changed the Library/Advanced/Visibility to Exclude and saved. Then when back and set it to Include in home screen and global search and saved. I set the library to rescan and then when to the home screen and the videos showed up.
