[SOLVED] Plex Server "Sharing" settings for an item is missing in the Web interface
Server Version#: Plex Server Version 1.19.5.3112
Player Version#: Web Interface Version 4.34.3
The “Sharing” menu which allows to set labels for items is missing from the web interface :
Plex Desktop / Plex Player (Sharing in 3rd position is present on the left menu) :
The very same panel (for the same movie) but from the Web Interface (no more sharing menu) :
I see that tab when using Web 4.34.3. Have you tried refreshing the browser?
Yes I refreshed the browser.
I encounter the same issue using safari browser on iOS and macOS.
The Plex user I’m using is the main plex pass user.
Ok I found what’s wrong : my AD Blocker is blocking this part of the server. I added it in the white pages and now it works.
It’s strange as it has been working well for month. Probably related to a filter update of AD Blocker.
[EDIT] : For the records, the culpirt is the filter Fanboy’s Social Blocking filter which is often included in the meta filter Fanboy’s Annoyances. I think the filter is triggered because the menu entry code probably contains a term that is something like share
