Sort By Folders & Switch between USERS on Console Apps
Is there a plan to add Sort By Folders & Switch between USERS on the PLEX Console Apps?
switching users should already be supported. it should show up under the user menu when you are on the dashboard,
https://forums.plex.tv/discussion/172617/multiple-user-accounts-on-xbox-one
Says that feature is not supported on Consoles… has this changed? as I do not see it on my Xbox One or PS4…
