Returning to this topic now I have my iTunes link working and all my content now in Plex. I have to say, it’s looking good. But sorting might still be an issue.
I specified for the music library that I wanted ‘oldest first’, in the initial library setup. I’m not really sure what that is supposed to control however. If I view by Album, can I not select the sort order on that page? Anyway…
I show the whole collection by Artist and they do seem to all follow the Sort (Album) Artist tags I have so laboriously configured. If I then select an artist, I am delighted to see all the albums apparently in chronological order. Is this the library setting above, or is it simply using the Sort Album tag/field which I configure to ensure correct release date order? Whatever, it is correct. But…
If I then try to play all tracks (play button at top left of Artist display) it plays the first track of the LATEST album, then the next track and presumably then works through the albums in the reverse order of how they are displayed. First of all, is this simply a bug and they forgot to sort the albums by the same criteria as for the actual display, or is there a way to change this? Is this the AlbumSort value stored in prefs? In which case…
How do I set that? I’m not being completely dumb here, but I would need to know the exact field name used by Plex for the Sort Album tag so I can ‘defaults write… etc’ and I have no idea what name Plex might use, or of how I could otherwise find out. Any documentation on this?
I tried a defaults read on AlbumSort but apparently it does not exist. So what value is Plex using and why is that not stored in prefs? Are the prefs just used to override hard coded options?
So, can I use the prefs AlbumSort option to control the album order when playing all tracks of an artist, is that what it’s for and how can I ascertain the field names it uses so I can set it how I want? Anyone?
@beckfield said:
@OttoKerner said:
@UKenGB said:
Sorting albums in reverse order is utterly incomprehensible to me and …Is there no way to correct this?
Not currently.
Yes there is. Take a look at this Help page.
