Is it still impossible to disable merging entirely?
tl;dr I never want items merged, I always want them “split apart”.
I like to give different editions different poster art.
I still consider the “release year” the same, however.
But even if the filenames are different, even if the metadata is different, with specifically different sort titles and different editions entered, Plex will merge them.
Even if you use “split apart”, it’s a huge pain trying to get it to select the correct poster art.
Since I’ve gone to the trouble of naming my files specifically, and their directories specifically, why does Plex then decide to override my logic?
Example, Battle Royale and Battle Royale: Special Edition.
Then in Plex:
And after using “split apart”:
I have my agents sorted to prioritize my locally created metadata. They’re in different folders. They have different titles, and different sort titles.
The year is the same, but theoretically two movies could come out with the same name in the same year (that isn’t the case here, but still.)
Once you’ve “split apart” an item, shouldn’t it be considered unique? And therefore scan that specific directory for poster art? Likewise, should it check for the title you’ve specified on that specific item (in this case one of them should read: Battle Royale: Special Edition).
Seems similar to:
Except in my case, the movies ARE the same, just different editions.
Since I go to the trouble of manually editing the metadata for each movie, and naming them/placing them in individual folders, having to manually edit each edition in Plex would be a lot of extra work.
