sqlite or other way?
Hi all,
I’d like to use a table for my plugin. Was thinking of:
Table: Person
<br />
handle   |   fullname      |   status   |   capability<br />
-------------------------------------------------------<br />
jjans    |   Jan Jansen    |   online   |   video<br />
ttijs    |   Theo Tijs     |   dnd      |   video<br />
mgrolsch |   Marie Grolsch |   offline  |   none<br />
so that in the plugin directory the fullname is being displayed as title.
When e.g. "Jan Jansen" is being clicked, the plugin finds the handle "jjans" from the table and does an action with the handle and not the fullname.
I think this is possible with sqlite, but I understand that there are (still) some problems with PMS and sqlit. Is this correct?
Check this [link](http://forums.plexapp.com/index.php/topic/22686-database-module/page__p__140508__hl__database__fromsearch__1#entry140508)
Any idea how to solve it or approach my thought from another direction?
thanks,
oortmanp
Hi!
Looking at the example data, you could probably just as easy use a Dict. Be sure to check out the changes regarding Dicts in version 2 of the framework.
Okay, actually I don't really get it
to create a dict:
dictname[key] = value
so e.g.
user[sander1] = Sander
But how can I put more than 1 value in 1 key?
user[sander1] = (Sander, AWAY, True, False)
And if that is possible, how can I retrieve for example the status (AWAY) from User "sander1"?
These might be basic questions, but I really don't know how to... :huh:
thanks,
oortmanp
user[sander1][0]=Sander
user[sander1][1]=AWAY
Thanks,
I also found out that .append should be possible
user = dict()
user[sander1] = ["Sander"]
user[sander1].append("AWAY")
or
user[sander1] = ["Sander", "AWAY", "..."]
