What I am currently missing is a override default view option, which can be set in the extended settings of each library.
The default setting, if a user does not make a customization via web client, is always: Card View.
But now I have two different libraries with series as an example:
Library A: Default Card View - it fits like this
Library B: Own videos with description (no meaningful cover) - Does not fit. I would like the “detail view” as default - even for my users.
I can now adjust this manually and tell all users, but if I go back to the library A, must be switched back to Card View. And vice versa again and again
Therefore I consider it VERY useful to be able to overwrite this value with an extended option per library.
Such an entry could look like this:
Library A -> Edit -> Advanced:
(checkbox) - override default view - SELECTION
Cheers deepwather
