I found an old forum post that seems to have died in 2012. I find the Storage Limit Slider control on iOS to be very limiting and lacks precision - it quickly jumps from 400 MB to 2 GB. Might i suggest replacing this with a simple numeric entry field, or a range selector?
I can totally second this. The slider is impossible to use precisely. As soon as I set the size I want, lifting my finger off the screen results in the slider jumping 10GB up or down.
