Strange Errors In a Log
Server Version#: 1.22.2.4282-6000
I am getting some continual errors in the Server Logs. How can I attach just a small portion here?
The DS is NOT running DSM 7. It is running 6.2.4-25556
Example Error Lines… (these are not right next to each other - just samples of lines)
XML: Unsupported encoding gbk
SSDP: Error parsing device schema for http://x.x.x.23:49152/upnpdevicedesc.xml
NetworkServiceBrowser: Parsing SSDP schema for http://x.x.x.25:49152/upnpdevicedesc.xml
HTTP/1.1 (0.0s) 200 response from GET http://x.x.x.25:49152/upnpdevicedesc.xml
One More piece — 23 and 25 are Hikvision Cameras. I disconnected them and the errors stopped. As far as I know I have never did anything to incorporate them into Plex.
You can ignore the messages.
The devices are announcing themselves on the network via SSDP. This is normal.
Plex Media Server does not understand their message format and notes it in the logs.
