STRM File
Hi there,
We are trying to integrate our app with plex.
We generate a stream available by example at http://localhost:62763
We generate a strm file on the fly, but:
We need to add it to plex. So how can w know what is the plex dir where we have to add it ? (it may be different on each os so we need to get it from plex directly)
OR
We send a request to plex saying, 'HEY SCAN THIS NEW DIR' (where we can generate a temp dir)
Please let me know how we can do something like that ..
Thanks a lot
Plex Channels don't have direct access to the local filesystem.  You may be able to figure this out with the API (I've never personally used it) but you'd probably want to ask this in the general dev section as opposed to the channel area specifically.
