The section in plexmediaserver.preinst which checks for the various Intel IGC components is a bit fragile - for example it will fail and print a warning if the packages are held to prevent upgrades (ie: dpkg -l starts with ‘hi’ rather than ‘ii’).
I suggest replacing the checks for these packages with something like:
[ “$(dpkg-query -f ‘${Version}\n’ -W intel-gmmlib 2>/dev/null)” = ‘21.3.3’ ] && HaveIntelGmmlib=1
[ “$(dpkg-query -f ‘${Version}\n’ -W intel-igc-core 2>/dev/null)” = ‘1.0.9441’ ] && HaveIntelIGCCore=1
[ “$(dpkg-query -f ‘${Version}\n’ -W intel-igc-opencl 2>/dev/null)” = ‘1.0.9441’ ] && HaveIntelIGCOpenCL=1
[ “$(dpkg-query -f ‘${Version}\n’ -W intel-opencl-icd 2>/dev/null)” = ‘21.49.21786’ ] && HaveIntelOpenCL=1
This confirms that a specific version is installed without reference to its status in the apt database.
Cleaner yet; I suggest defining a quick function just before the section which checks for existing packages; like:
dpkg-version() {
dpkg-query -f '${Version}\n' -W "$1" 2>/dev/null
and then using that to check for specific versions of the various packages:
# Beignet
[ "$(dpkg-version beignet-opencl-icd)" != "" ] && HaveBeignet=1
# ICR Packages (version 21.49.21786)
[ "$(dpkg-version intel-gmmlib)" = "21.3.3" ] && HaveIntelGmmlib=1
[ "$(dpkg-version intel-igc-core)" = "1.0.9441" ] && HaveIntelIGCCore=1
[ "$(dpkg-version intel-igc-opencl)" = "1.0.9441" ] && HaveIntelIGCOpenCL=1
[ "$(dpkg-version intel-opencl-icd)" = "21.49.21786" ] && HaveIntelOpenCL=1
# OpenCL (Required regardless of which Tone Mapping solution installed)
[ "$(dpkg-version ocl-icd-libopencl1)" != "" ] && HaveOpenCL=1
@colmbuckley
Why don’t you join us in the main thread ?
ALL;
I’ve been working to update the Ubuntu/Debian packaging to account for how Ubuntu 22.04 repository packages have changed.
I’ve selected 1.26.1.5772 for testing purposes as its database is compatible with 1.26.0 and above.
EDIT:
Changes incorporated
The preinstaller is now sensitive to:
– CPU (including Alderlake)
– Distribution
– Release version
Using these three pieces of data, the preinstaller now compares what’s installed against what is needed and reports accordingly.
T…
I will move your posts there if you wish.
This is good voodoo
PS: I did spot the hi/ii status issue and corrected with a regex. Your suggestion sounds like it might cover all cases ?
Sounds good - please move my suggestions over to that thread and we can continue the discussion there.
… actually, having read that thread, I’ve added the relevant small suggestion which I think covers everything I’d like to see.
Thanks.
