Sync Movies without transcode
I just paid for a lifetime subscription, because I want to sync to mobile devices. I have a horrible feeling I’ve made a real blunder. I can’t see how to sync movies without transcode. Surely this is possible? If not, I guess I will need to beg for a refund.
Unfortunately there is no option to sync movies without transcode. I wish this feature too.
The UI shouldn’t be showing a conversion if what you’re trying to sync is indeed DirectPlay ready for that device.
If you’ve found an exception where this is not true, please get the media info (or XML) for what you’re trying to sync and tell me what you’re trying to sync to.
I’ll check here and see what’s happening.
Here is an example - it streams without issue, I can download using iTunes with no issue & playback, but Plex sync insists on converting.
If I can’t overcome this, it is pretty much useless.
Chris
General
Complete name : /Volumes/QnapVideo3TB-2/Straight Outta Compton (Unrated Dire.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/isom)
File size : 5.64 GiB
Duration : 2h 46mn
Overall bit rate mode : Variable
Overall bit rate : 4 843 Kbps
Movie name : Straight Outta Compton (Unrated Director’s Cut)
Performer : F. Gary Gray
Genre : Drama
Description : In 1987, five young men, using brutally honest rhymes and hardcore beats, put their frustration and
Recorded date : UTC 2015-08-14 07:00:00
Encoded date : UTC 2016-01-19 11:21:04
Tagged date : UTC 2016-01-19 11:41:18
Cover : Yes
LongDescription : Straight Outta Compton UNRATED Director’s Cut includes never before seen footage and tells the true story of how five young cultural rebels - armed only with their lyrics, swagger, bravado and raw talent - stood up to the authorities that meant to keep them down and formed the world’s most dangerous group, N.W.A. And as they spoke the truth that no one had before and exposed life in the hood, their voice ignited a social revolution that is still reverberating today.
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Format settings, GOP : M=2, N=90
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2h 46mn
Bit rate : 4 077 Kbps
Width : 1 280 pixels
Height : 532 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Variable
Frame rate : 23.976 fps
Minimum frame rate : 23.976 fps
Maximum frame rate : 27.245 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.250
Stream size : 4.75 GiB (84%)
Language : English
Encoded date : UTC 2016-01-19 11:38:57
Tagged date : UTC 2016-01-19 11:40:43
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 2h 46mn
Duration_LastFrame : -13ms
Bit rate mode : Variable
Bit rate : 123 Kbps
Maximum bit rate : 211 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Frame rate : 46.875 fps (1024 spf)
Compression mode : Lossy
Stream size : 147 MiB (3%)
Language : English
Default : Yes
Alternate group : 1
Encoded date : UTC 2016-01-19 11:21:08
Tagged date : UTC 2016-01-19 11:26:15
Menus : 13
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : ac-3
Duration : 2h 46mn
Duration_LastFrame : -24ms
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Frame rate : 31.250 fps (1536 spf)
Bit depth : 16 bits
Stream size : 458 MiB (8%)
Language : English
Default : No
Alternate group : 1
Encoded date : UTC 2016-01-19 11:26:15
Tagged date : UTC 2016-01-19 11:28:22
Audio #3
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 46mn
Bit rate : 125 Kbps
Maximum bit rate : 210 Kbps
Stream size : 149 MiB (3%)
Language : French
Default : No
Alternate group : 1
Encoded date : UTC 2016-01-19 11:28:22
Tagged date : UTC 2016-01-19 11:33:32
Audio #4
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 46mn
Bit rate : 126 Kbps
Maximum bit rate : 228 Kbps
Stream size : 150 MiB (3%)
Language : Spanish
Default : No
Alternate group : 1
Encoded date : UTC 2016-01-19 11:33:32
Tagged date : UTC 2016-01-19 11:38:57
Text #1
Format : Timed Text
Muxing mode : sbtl
Codec ID : tx3g
Duration : 1s 0ms
Bit rate : 264 bps
Stream size : 33.0 Bytes (0%)
Language : English
Default : Yes
Forced : No
Alternate group : 2
Encoded date : UTC 2016-01-19 11:40:44
Tagged date : UTC 2016-01-19 11:40:46
Text #2
Format : Timed Text
Muxing mode : sbtl
Codec ID : tx3g
Duration : 2h 46mn
Bit rate : 26 bps
Stream size : 32.0 KiB (0%)
Language : French
Default : No
Forced : No
Alternate group : 2
Encoded date : UTC 2016-01-19 11:40:46
Tagged date : UTC 2016-01-19 11:40:49
Text #3
Format : Timed Text
Muxing mode : sbtl
Codec ID : tx3g
Duration : 2h 46mn
Bit rate : 132 bps
Stream size : 161 KiB (0%)
Language : French
Default : No
Forced : No
Alternate group : 2
Encoded date : UTC 2016-01-19 11:40:50
Tagged date : UTC 2016-01-19 11:40:54
Forced Alternative : 7
Text #4
Format : Timed Text
Muxing mode : sbtl
Codec ID : tx3g
Duration : 2h 41mn
Bit rate : 2 bps
Stream size : 1.88 KiB (0%)
Language : Spanish
Default : No
Forced : No
Alternate group : 2
Encoded date : UTC 2016-01-19 11:40:55
Tagged date : UTC 2016-01-19 11:40:57
Text #5
Format : Timed Text
Muxing mode : sbtl
Codec ID : tx3g
Duration : 2h 41mn
Bit rate : 126 bps
Stream size : 150 KiB (0%)
Language : Spanish
Default : No
Forced : No
Alternate group : 2
Encoded date : UTC 2016-01-19 11:40:58
Tagged date : UTC 2016-01-19 11:41:02
Forced Alternative : 9
Text #6
Format : Timed Text
Muxing mode : sbtl
Codec ID : tx3g
Duration : 2h 41mn
Bit rate : 156 bps
Stream size : 184 KiB (0%)
Language : English
Default : No
Forced : No
Alternate group : 2
Encoded date : UTC 2016-01-19 11:41:03
Tagged date : UTC 2016-01-19 11:41:08
Forced Alternative : 6
Text #7
Format : EIA-608
Muxing mode : Final Cut
Codec ID : c608
Duration : 2h 46mn
Stream size : 0.00 Byte (0%)
Language : English
Default : No
Forced : No
Alternate group : 2
Encoded date : UTC 2016-01-19 11:41:09
Tagged date : UTC 2016-01-19 11:41:13
Menu
Codec ID : text
Duration : 2h 46mn
Encoded date : UTC 2016-01-19 11:41:18
Menu For : 1
00:00:00.000 : 1
00:05:48.000 : 2
00:09:55.000 : 3
00:17:32.000 : 4
00:26:34.000 : 5
00:35:38.000 : 6
00:47:28.000 : 7
00:55:38.000 : 8
01:04:42.000 : 9
01:11:25.000 : 10
01:19:00.000 : 11
01:25:47.000 : 12
01:33:56.000 : 13
01:44:21.000 : 14
01:54:03.000 : 15
02:02:53.000 : 16
02:16:12.000 : 17
02:26:24.000 : 18
02:33:06.000 : 19
02:39:21.000 : 20
Bit rate mode : VBR
You can mess with your sync xml profiles and force it to not convert however ymmv with it actually playing on the device as there is no transcoding available on the cloud sync server and you may need to back up modified xml files between updates.
on the sync screen you can choose the bitrate, on option being “original” ?
But not for audio …
Is there a description of how to do this anywhere?
It’s unsupported but here is a guide that someone wrote to change it for chromecast
basically just put whatever settings you want for the device that you want to sync to or the cloud sync profile
