sudo: ufw: command not found
osmc@osmc:/etc/default$
Can’t do it
osmc@osmc:/etc/default$ sudo apt-get --reinstall plexmediaserver-installer
E: Command line option --reinstall is not understood in combination with the other options
My fault. sudo apt-get install --reinstall plexmediaserver-installer
I reinstalled it, rebooted RPi and the same thing
This site can’t be reached
192.168.1.154 refused to connect.
Did you try http://192.168.1.154:32400/web as well as https://192.168.1.154:32400/web?
Also let’s take a look at the last log entries: sudo tail -n 30 /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Logs/Plex\ Media\ Server.log
As I said, no logs are generated. I have only the old one, as a result of your command.
osmc@osmc:/var/lib/plexmediaserver/Library/Application Support/Plex Media Server$ sudo tail -n 30 /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Logs/Plex\ Media\ Server.log
Aug 06, 2018 20:02:55.600 [0x689ff400] DEBUG - HTTP requesting PUT https://plex.tv/api/servers/a6c1ac40a3f10878495b36bbf2f20d1098262b6d/connectivity?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&asyncIdentifier=de96c8d9-1126-4396-a8ae-877f7e3e0fa2
Aug 06, 2018 20:02:56.214 [0x689ff400] DEBUG - HTTP 200 response from PUT https://plex.tv/api/servers/a6c1ac40a3f10878495b36bbf2f20d1098262b6d/connectivity?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&asyncIdentifier=de96c8d9-1126-4396-a8ae-877f7e3e0fa2
Aug 06, 2018 20:02:56.215 [0x729ff400] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (6b0c89b6-59bd-40bb-b0c4-ee45153f35e2, expected de96c8d9-1126-4396-a8ae-877f7e3e0fa2)
Aug 06, 2018 20:02:56.215 [0x729ff400] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (6b0c89b6-59bd-40bb-b0c4-ee45153f35e2, expected 0a2b8e9f-2d10-4c8b-87c0-a1c13754e35b)
Aug 06, 2018 20:02:56.219 [0x729ff400] DEBUG - EventSource: Resolving 50.116.59.4 port 443s
Aug 06, 2018 20:02:56.220 [0x729ff400] DEBUG - EventSource: Resolving 50.116.59.4 port 443s
Aug 06, 2018 20:02:56.220 [0x729ff400] DEBUG - EventSource: Failure in IdleTimeout (0 - Success).
Aug 06, 2018 20:02:56.220 [0x729ff400] DEBUG - MyPlex: We appear to have lost Internet connectivity, resetting device URL cache.
Aug 06, 2018 20:02:56.220 [0x729ff400] ERROR - EventSource: Retrying in 15 seconds.
Aug 06, 2018 20:02:56.222 [0x729ff400] DEBUG - Auth: authenticated user 1 as ziggy.ignatowicz@gmail.com
Aug 06, 2018 20:02:56.223 [0x691ff400] DEBUG - Request: [192.168.1.134:52205 (Subnet)] GET /media/providers (10 live) GZIP Signed-in Token (ziggy.ignatowicz@gmail.com)
Aug 06, 2018 20:02:56.223 [0x729ff400] DEBUG - Completed: [192.168.1.134:52212] 200 PUT /myplex/refreshReachability (10 live) GZIP 24396ms 268 bytes (pipelined: 2)
Aug 06, 2018 20:02:56.223 [0x729ff400] DEBUG - EventSource: Got event [data] ‘’
Aug 06, 2018 20:03:03.400 [0x6a3ff400] DEBUG - [CompanionProxy] player ymhhnfei7a9j24vr2jte0qes was last refreshed 20 seconds ago
Aug 06, 2018 20:03:05.814 [0x711ff400] DEBUG - NAT: UPnP, didn’t find usable IGD.
Aug 06, 2018 20:03:05.829 [0x643ff400] DEBUG - NAT: UPnP, didn’t find usable IGD.
Aug 06, 2018 20:03:06.539 [0x62bff400] DEBUG - NAT: UPnP, getPublicIP didn’t find usable IGD.
Aug 06, 2018 20:03:06.539 [0x64bff400] DEBUG - NAT: UPnP, getPublicIP didn’t find usable IGD.
Aug 06, 2018 20:03:13.400 [0x6a3ff400] DEBUG - [CompanionProxy] player ymhhnfei7a9j24vr2jte0qes was last refreshed 30 seconds ago
Aug 06, 2018 20:03:16.540 [0x64bff400] WARN - NAT: PMP, timed out waiting for response.
Aug 06, 2018 20:03:16.541 [0x711ff400] DEBUG - PublicAddressManager: Mapping failed.
Aug 06, 2018 20:03:16.542 [0x62bff400] WARN - NAT: PMP, timed out waiting for response.
Aug 06, 2018 20:03:16.543 [0x643ff400] DEBUG - PublicAddressManager: Mapping failed.
Aug 06, 2018 20:03:16.544 [0x653ff400] DEBUG - MyPlex: Sending Server Info to myPlex (user=ziggy.ignatowicz@gmail.com, ip=, port=0)
Aug 06, 2018 20:03:16.550 [0x653ff400] DEBUG - HTTP requesting POST https://plex.tv/servers.xml?auth_token=xxxxxxxxxxxxxxxxxxxx&async=1&asyncIdentifier=d07f1706-ecce-4c6b-abb6-8bed0e5b5330
Aug 06, 2018 20:03:16.748 [0x62bff400] DEBUG - MyPlex: Updating device connections (from timer: 0)
Aug 06, 2018 20:03:16.749 [0x62bff400] DEBUG - HTTP requesting PUT https://plex.tv/devices/a6c1ac40a3f10878495b36bbf2f20d1098262b6d?Connection[][uri]=http://192.168.1.154:32400&httpsEnabled=1&httpsRequired=0&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Aug 06, 2018 20:03:16.755 [0x67fff400] DEBUG - Job running: ‘/usr/lib/plexmediaserver/CrashUploader’ ‘–directory=/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Crash Reports/1.13.5.5291-6fa5e50a8’ ‘–version=1.13.5.5291-6fa5e50a8’ ‘–platform=linux-annapurnatrans-arm7 (4.14.34-2-osmc (#1 SMP PREEMPT Thu Jun 7 18:43:25 UTC 2018))’ ‘–serverUuid=a6c1ac40a3f10878495b36bbf2f20d1098262b6d’ ‘–userId=NOUSERID’ ‘–url=https://crashreport.plexapp.com’
Aug 06, 2018 20:03:16.761 [0x67fff400] DEBUG - Jobs: Starting child process with pid 25161
I suppose you do not have anything to lose, so please clean the Plex data and start from scratch:
# stop pms
sudo systemctl stop plexmediaserver
# clean PMS data
sudo rm -r /var/lib/plexmediaserver/Library/
# start pms
sudo systemctl start plexmediaserver
It Works !!!strong text
Thank you so much.
Actually, I added the same folder, and it crashed again, but recovered later on its own. Now it is working. I am not familiar so I have to play a little more.
I didn’t see left hand menu before, so my old installation was not complete.
Than you very much for your help and patience.
Ziggy
