First time this has happened to me after a reasonably long time of the server being stable. Just tried to open plex and the local servers were offline, ran status and this was the result
I’m not sure what to do next, my linux skills don’t extend much beyond the basics and copy and pasting but thought I’d ask here
Jun 01 11:40:49 PlexyPi2021 systemd[1]: plexmediaserver.service: Service RestartSec=5s expired, scheduling restart.
Jun 01 11:40:49 PlexyPi2021 systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 3.
Jun 01 11:40:49 PlexyPi2021 systemd[1]: Stopped Plex Media Server.
Jun 01 11:40:49 PlexyPi2021 systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Jun 01 11:40:49 PlexyPi2021 systemd[1]: plexmediaserver.service: Failed with result ‘signal’.
Jun 01 11:40:49 PlexyPi2021 systemd[1]: Failed to start Plex Media Server.
Thanks for the reply. I had a clean install from a couple of months ago so reinstalled that ah oh worked great and then copied the two dB files over and the same thing happened again so I presume that those two files were corrupted somehow so just used the backup and updated from that time point. Seems fine now.
I’ve also been encountering this issue. I have an RPi B+ with the latest Raspbian OS /packages, I’ve added the official repo and installed, but so far plexmediaserver has failed to start with Result: Signal every time:
systemctl status plexmediaserver
● plexmediaserver.service - Plex Media Server
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/plexmediaserver.service.d
└─override.conf
Active: failed (Result: signal) since Mon 2021-06-28 18:00:33 BST; 5s ago
Process: 1059 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}
Process: 1061 ExecStart=/bin/sh -c export PLEX_MEDIA_SERVER_INFO_VENDOR="$(grep ^NAME= /etc/os-rele
Main PID: 1061 (code=killed, signal=SEGV)
Jun 28 18:00:33 snespi systemd[1]: plexmediaserver.service: Service RestartSec=5s expired, scheduling
Jun 28 18:00:33 snespi systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is
Jun 28 18:00:33 snespi systemd[1]: Stopped Plex Media Server.
Jun 28 18:00:33 snespi systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Jun 28 18:00:33 snespi systemd[1]: plexmediaserver.service: Failed with result 'signal'.
Jun 28 18:00:33 snespi systemd[1]: Failed to start Plex Media Server.
My override.conf file is just there to try and change the user and group to the default pi user, and I’ve recursively chowned the /var/lib/plexmediaserver/ directory to pi:pi (also tried the same by ensuring that was owned by the Plex user).
I’ve blown away my Plex install on this Pi and restarted a couple times but keep hitting the same issue.
Here’s the recent output from sudo journalctl -xe | grep -I plex:
Jun 28 18:07:52 snespi systemd[1]: /etc/systemd/system/plexmediaserver.service.d/override.conf:1: Assignment outside of section. Ignoring.
Jun 28 18:07:52 snespi systemd[1]: /etc/systemd/system/plexmediaserver.service.d/override.conf:2: Assignment outside of section. Ignoring.
Jun 28 18:08:24 snespi systemd[1]: Starting Plex Media Server...
-- Subject: A start job for unit plexmediaserver.service has begun execution
-- A start job for unit plexmediaserver.service has begun execution.
Jun 28 18:08:24 snespi systemd[1]: Started Plex Media Server.
-- Subject: A start job for unit plexmediaserver.service has finished successfully
-- A start job for unit plexmediaserver.service has finished successfully.
Jun 28 18:08:25 snespi systemd[1]: plexmediaserver.service: Main process exited, code=killed, status=11/SEGV
-- An ExecStart= process belonging to unit plexmediaserver.service has exited.
Jun 28 18:08:25 snespi systemd[1]: plexmediaserver.service: Failed with result 'signal'.
-- The unit plexmediaserver.service has entered the 'failed' state with result 'signal'.
Jun 28 18:08:30 snespi systemd[1]: plexmediaserver.service: Service RestartSec=5s expired, scheduling restart.
Jun 28 18:08:30 snespi systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 1.
-- Automatic restarting of the unit plexmediaserver.service has been scheduled, as the result for
Jun 28 18:08:30 snespi systemd[1]: Stopped Plex Media Server.
-- Subject: A stop job for unit plexmediaserver.service has finished
-- A stop job for unit plexmediaserver.service has finished.
Jun 28 18:08:30 snespi systemd[1]: Starting Plex Media Server...
Jun 28 18:08:30 snespi systemd[1]: Started Plex Media Server.
Jun 28 18:08:31 snespi systemd[1]: plexmediaserver.service: Main process exited, code=killed, status=11/SEGV
Jun 28 18:08:31 snespi systemd[1]: plexmediaserver.service: Failed with result 'signal'.
Jun 28 18:08:36 snespi systemd[1]: plexmediaserver.service: Service RestartSec=5s expired, scheduling restart.
Jun 28 18:08:36 snespi systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 2.
Jun 28 18:08:36 snespi systemd[1]: Stopped Plex Media Server.
Jun 28 18:08:36 snespi systemd[1]: Starting Plex Media Server...
Jun 28 18:08:36 snespi systemd[1]: Started Plex Media Server.
Jun 28 18:08:36 snespi systemd[1]: plexmediaserver.service: Main process exited, code=killed, status=11/SEGV
Jun 28 18:08:36 snespi systemd[1]: plexmediaserver.service: Failed with result 'signal'.
Jun 28 18:08:41 snespi systemd[1]: plexmediaserver.service: Service RestartSec=5s expired, scheduling restart.
Jun 28 18:08:41 snespi systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 3.
Jun 28 18:08:41 snespi systemd[1]: Stopped Plex Media Server.
Jun 28 18:08:41 snespi systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Jun 28 18:08:41 snespi systemd[1]: plexmediaserver.service: Failed with result 'signal'.
Jun 28 18:08:41 snespi systemd[1]: Failed to start Plex Media Server.
-- Subject: A start job for unit plexmediaserver.service has failed
-- A start job for unit plexmediaserver.service has finished with a failure.
Jun 28 18:10:02 snespi su[589]: pam_unix(su:auth): authentication failure; logname=pi uid=1000 euid=0 tty=pts/0 ruser=pi rhost= user=plex
Jun 28 18:10:04 snespi su[589]: FAILED SU (to plex) pi on pts/0
Jun 28 18:11:37 snespi sudo[626]: pi : TTY=pts/0 ; PWD=/var/lib/plexmediaserver/Library/Application Support/Plex Media Server ; USER=root ; COMMAND=/usr/bin/journalctl -xe
Appreciate any help or tips on this one - been going in circles.
