how come some tv shows play theme music and some do not when you click on it?? any way to make sure ALL tv shows play the preview theme song??
Not all tv shows have a theme music ready for download
https://support.plex.tv/hc/en-us/articles/201178657-Current-TV-Themes
can you ADD theme music in mp3 format to the tv series folder???
Let’s see if I can intercept that pass and run in for the touchdown… ![]()
Why, yes, you can:
https://support.plex.tv/hc/en-us/articles/200220717
TV Shows/
…Heroes/
…Season 01/
…Heroes - s01e01 - Genesis.avi <— (AVI files should be a crime, but let’s continue anyway)
…theme.mp3
The theme.mp3 belongs into the show folder, not into the seasons folder.
so, let me see if I have this correct…
tv shows
timeless [2016]
season 01
put the theme.mp3 INTO the season 01 folder NOT the timesless [2016] folder… correct??
Nope.
TV Shows/
…Heroes/
…theme.mp3
…Season 01/
The play is ruled an incomplete pass… awwwwww. And here I go trusting the documentation yet again (it’s my own fault, really):
As it’s written:
/TV Shows
/Heroes
/Season 01
theme.mp3 <---- (no, that's not confusing at all, is it?)
As it works in real life:
A TV Show Library/
…Heroes/
…theme.mp3
…Season 01/
…Heroes - S01E01 - Genesis.mp4 <---- (there we go - all better now)
well its not working…
put the theme.mp3 into the show folder… and its not playing through the plex media player OR roku
AH… the theme.mp3, needs to be renamed to the NAME of the episode??
No, Otto was right. Just put the file in the main show folder.
(serves me right going up against Team Kerner with 11 Grandmothers in Wheelchairs
No.
it needs to be named theme.mp3
You must check your agent configuration.
‘Local Media Assets’ must be active and must sit above of ‘Plex Theme Music’
(But don’t drag it into the topmost position!)
Afterwards, Refresh the show. (the whole show, not just the season and not just an episode)
BINGO…thank you
Hi All
I’m having similar problems, I currently have 3 Tv Shows: King of Queens, Pj Mask, and the Simpsons.
The only theme music that works is The Simpsons. I named them “theme.mp3” and put them in there Tv Show Folders(not season) as instructed above. I thought maybe it was the mp3 file so i took the simpson “theme.mp3” and put it in the pj mask folder just for an experiment. Funny,Plex Media Server Logs_2018-07-30_12-47-11.zip (1.1 MB)
it still plays the Simpsons theme song and nothing play for Pj mask…lol
I have my agents set as follows and included my log.
Your help will be greatly appreciated. Version 1.13.4.5271
Please post the Plex XML info of the first episode of ‘PJ Masks’.
Pj Mask First episode.xml.zip (1.4 KB)
https://198-16-196-101.0294a54d9e894e44b1fac88c60e3ff21.plex.direct:24638/library/metadata/438?checkFiles=1&includeExtras=1&includeBandwidths=1&X-Plex-Token=ghKZQpqFntfrvrpptZra
Hm, this one is properly matched with the TMDB.
Did you ‘Refresh Metadata’ for the whole show?
If that doesn’t help, try ‘Fix Match’ and use TheTVDB this time.
