TheTVDB agent preferences (season sorting)
Server Version#: 1.19.4.2893
Player Version#: 1.11.0.1215-1d8c460c
is there a way to choose from “Aired Order” “DVD Order”, “Absolute Order” and so on instead using default sort?
In particular, I’m having problems with “Chilling adventures of Sabrina”, that shows “Seasons”, “Absolute Order” and “Parts”. I need Parts order that is perfect for my needs, because I have titles grouped in this way on my disk.
Thank you.
  1. Open your Plex library in Plex Web (Plex for Mac/Windows clients will also do the job)
  2. Navigate to the show and click Edit > Advanced > Episode ordering
  3. select from Aired order, DVD order or Absolute order
This defaults to Aired order.
Edit:
No Parts order… so you probably need to go with the Aired order instead
Thank you, that worked! Absolute order it worked, although I would have preferred to use parts order , because I have episodes splitted in 3 seasons, and I had to rename all 28 episodes in one big season to let agent works.
thank you
Yeah, sadly Plex does not yet support those “alternate orders” from TheTVDB. Please vote here to help get it supported: Support Alternate Order / Flexible Seasons (TVDB) and Episode Groups (TMDB)
