Three simple Home screen bugs
Server Version#: 1.40.5.8796
Player Version#: 10.19.2.1191
Hi, I am using a Sony A95K and notced a couple of glitches, compared to using my iPad client,
  1. ‘Continue Watching’ reel on Home page.
On my iPad, if i watch half of an anime that has no meta/poster, afterwards, the title appears on the Home ‘Continue Watching’ reel, and it is displayed also with no poster/black as I expect. On the Sony, it instead shows the last frame you were watching. Presumably, it should be consistent on both devices, I kinda prefer the black poster because often times the last frame is just a blur so doesn’t look very appealing in the feed, whereas on iPad it looks quite clean.
  1. On the Sony, if you hide any title on the Continue Watching reel, I expected the tag to be remembered but if you change the tab to Trending and then back to Home, the hidden entry has reappeared.
  2. On the Sony, if you change the Home page to Trending or any other tab, the navigation css does not move the underline from under the Home tab, to the tab that you are now viewing.
