Time on screen not going away
Why is the time on the screen not going away after a recent upgrade. It keeps on showing until you press the up arrow of the Apple TV remote.
I have this problem too...
//BTILAF
Both: Really? All the time? Just some files? Anything in the logs? And it's not your TV clock, is it? :-D
What I mean is that in the lower part of the screen it says for example "Ends at 11:34".
I managed to make it go away by entering "showplayerclock = False" in ATVSettings.cfg in the section for the actual ATV unit.
The question is if it is supposed to stay on the screen at all and that you have to use the up or down on the remote to make it go away?
Strange... I don't see this issue here. "Ends at" disappears, when the progress bar fades away.
Could you please re-enable that display (there is a setting in the PlexConnect/Seetings menu for that) and provide a log? What is the clock setting? Enabled? Position? Host-OS (no idea, how that could effect it, though), iOS version?
I have the same behavior.
It goes away if I press pause/play,
Didn't we see the same issue in the early days of plexconnect ? back then it was caused by the language/subtitle settings in PMS (if i remember correctly).
I observe the same behaviour btw.
So? Still waiting for some logs...
