Today I had to switch to Rasbmc /w USB. I could not deal with the slowness plus its was not "Wife approved" I will be back just need to Rasplex to grow a little more. HURRY!!!
I dont have any slowless tbh, and Im not even using a wired connection
My set up is faster than raspbmc, what are you using?
With a Class 10 SD card and using the "Refocus" skin, I have very little if any lag. Everything loads really fast! Sure, it isn't *quite* as smooth as browsing videos in Netflix, but it is almost as good (and I am confident that it will improve with each update :) )
I had the biggest speed/responding problems with a bad power supply.
Might be a good start to look into your gear before demanding more [free] work from the developer.
I'M BACK for now I tried the reFocus skin and it is faster but a horrible looking skin, I am using a 8GB class 10 SD w/ a 16GB USB 3.0 thumb drive (I know the ports are only 2.0) power supply is a black berry charger. And when said rasplex needs to grow i was talking about the lack of channel support, usb support,faster scrolling, and faster fan out which i know they are hard at work on. GO DEV TEAM!!!!
Are any of you overclocking your Pi's
I'm overclocking mine to 900Mhz and doing overvoltage=2 :)
As I can remember a BB charger only outputs 700mAh, thats bare minimum for a Pi to work without USB. Try getting a more powerfull one like 1Amp or more, you'll notice more stability and performance :)
