Server Version#: 1.13.9.5456
Player Version#: Web Client 3.73.2
Server uses hardware transcoding, Intel E3-1245v6. Ubuntu 16.04 LTS
When trying to sync Atomic Blonde remux to my iPad with hardware transcoding allowed, the trancoder fails to fall back to software decoding, and the entire sync fails.
If I do the same thing but streaming instead (same settings, 20mbit 1080p), hardware decoding also fails but it successfully falls back to software decoding.
Attached logs of the sync failure, the streaming fallback, as well as the mediainfo of the file.
1st question: Why is VAAPI failing on this particular file?
2nd question: Why does software decoding fallback not work for sync?
Then collect the full DEBUG log zip (Settings - Server - troubleshooting - download logs)
It’s easier for you and for me when all are in one file (ZIP)
I strongly suggest you start over in the docker image.
In the future, Docker is not for the Linux forum, even if hosted on a Linux machine. (It’s that unique)
In the future, an orderly shutdown of the active image will prevent this. Somehow it was ‘hard terminated’. The DB didn’t have the opportunity to write all info to disk.
Nov 06, 2018 13:07:42.188 [0x7fa159bfe700] INFO - Plex Media Server v1.13.4.5271-200287a06 - Docker Docker Container x86_64 - build: linux-ubuntu-x86_64 ubuntu - GMT -06:00
Nov 06, 2018 13:07:42.188 [0x7fa159bfe700] INFO - Linux version: 4.18.14-200.fc28.x86_64 (#1 SMP Mon Oct 15 13:16:27 UTC 2018), language: C
Nov 06, 2018 13:07:42.188 [0x7fa159bfe700] INFO - Processor Intel(R) Xeon(R) CPU E3-1245 v6 @ 3.70GHz
Nov 06, 2018 13:07:42.188 [0x7fa159bfe700] INFO - /usr/lib/plexmediaserver/Plex Media Server
Nov 06, 2018 13:07:42.190 [0x7fa165b5f800] INFO - SQLITE3:0x10, 283, recovered 293 frames from WAL file /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Nov 06, 2018 13:07:42.519 [0x7fa1583ff700] INFO - CodecManager: obtaining decoder 'aac'
Nov 06, 2018 13:07:42.527 [0x7fa165b5f800] INFO - OCSP: Successfully retrieved response from cache.
Nov 06, 2018 13:07:43.758 [0x7fa14dbf3700] ERROR - SQLITE3:0x10, 11, database corruption at line 112037 of [fc49f556e4]
You are having all kinds of connectivity errors and, unfortunatley, being docker, I don’t know how that translates to the host layer getting out to Plex.tv. It’s reasons like this I never use it. With the level of portability Linux natively affords, I find docker an encumbering layer of abstraction which serves me no purpose other than heartburn.
Nov 08, 2018 22:53:56.412 [0x7fe2bdffe700] INFO - Plex Media Server v1.13.4.5271-200287a06 - Docker Docker Container x86_64 - build: linux-ubuntu-x86_64 ubuntu - GMT -06:00
Nov 08, 2018 22:53:56.412 [0x7fe2bdffe700] INFO - Linux version: 4.18.14-200.fc28.x86_64 (#1 SMP Mon Oct 15 13:16:27 UTC 2018), language: C
Nov 08, 2018 22:53:56.412 [0x7fe2bdffe700] INFO - Processor Intel(R) Xeon(R) CPU E3-1245 v6 @ 3.70GHz
Nov 08, 2018 22:53:56.412 [0x7fe2bdffe700] INFO - /usr/lib/plexmediaserver/Plex Media Server
Nov 08, 2018 22:53:56.510 [0x7fe2c9e04800] ERROR - Error opening file '"/config/Library/Application Support/Plex Media Server/Cache/OCSP/main.der"' - No such file or directory (2)
Nov 08, 2018 22:53:56.556 [0x7fe2b9fff700] ERROR - OCSP: response error: unauthorized.
Nov 08, 2018 22:53:56.556 [0x7fe2b9fff700] INFO - OCSP: couldn't fetch a valid response; retrying in 10800 seconds
Nov 08, 2018 22:53:57.677 [0x7fe2b47fe700] INFO - LibraryUpdateManager path watching is disabled
Nov 08, 2018 22:53:59.387 [0x7fe2b27fd700] INFO - Sync: downloaded 0 sync list(s) with 0 sync items(s): 0 new, 0 updated, 0 deleted
Nov 08, 2018 22:54:19.880 [0x7fe2b7fff700] WARN - NAT: PMP, timed out waiting for response.
Nov 08, 2018 22:54:19.881 [0x7fe2bb7ff700] ERROR - EventSource: Retrying in 15 seconds.
Nov 08, 2018 22:54:42.135 [0x7fe2b8fff700] WARN - NAT: PMP, timed out waiting for response.
Nov 08, 2018 22:54:42.690 [0x7fe2bb7ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (04134a8a-d826-4674-bd07-0660768154e4, expected a0f19976-f65e-4d94-bf91-d91a7137b0c2)
Nov 08, 2018 22:54:42.691 [0x7fe2baffe700] ERROR - EventSource: Retrying in 30 seconds.
Nov 08, 2018 22:54:44.788 [0x7fe2bb7ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (80462bf0-c031-49ac-9817-c8fceed05c09, expected c2f119f1-d49e-4a77-b433-7bd92b4b52ea)
Nov 08, 2018 22:54:45.506 [0x7fe2bb7ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (a0f19976-f65e-4d94-bf91-d91a7137b0c2, expected c2f119f1-d49e-4a77-b433-7bd92b4b52ea)
Nov 08, 2018 22:54:45.506 [0x7fe2bb7ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (a9b219e1-7101-4478-bb37-64d7b1881800, expected c2f119f1-d49e-4a77-b433-7bd92b4b52ea)
Nov 08, 2018 22:54:45.506 [0x7fe2bb7ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (81951b4f-a782-4caa-bd53-053ee0195323, expected c2f119f1-d49e-4a77-b433-7bd92b4b52ea)
Nov 08, 2018 22:54:45.506 [0x7fe2bb7ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (b176f72f-37e8-453c-9924-af705746dfc2, expected c2f119f1-d49e-4a77-b433-7bd92b4b52ea)
Nov 08, 2018 22:55:05.476 [0x7fe2b6fff700] WARN - NAT: PMP, timed out waiting for response.
Nov 08, 2018 22:55:12.691 [0x7fe2baffe700] ERROR - EventSource: Retrying in 15 seconds.
Nov 08, 2018 22:55:50.472 [0x7fe2a47fd700] WARN - NAT: PMP, timed out waiting for response.
