Transcoding issue
Hi Plex Community,
I have an transcoding issue while playing mkv files.
The movie starts fine in atv and after a while it stops transcoding, the screen turns into green, the sound still works but just a green image. Btw all the movies are working fine on Plex iphone/ipad, Plex Home Theater and VLC but not on MplayerX(it starts 10seconds with a multicolor screen and then it close the programm)
I am on OSX 10.9.1, lastest version of PMS and PlexConnect
Cant figure out what i could be…
Any ideas?
Thx in advance
I am also having transcoding issues with certain MKV's.  I cannot seem to figure out the common ground as to how these videos are different.  They work find with a plethora of different media players on my mac, but just don't stream to the AppleTV.  Also, the same movies do not work with Beamer as well, something is up with this certain type.
Examples that worked
[mediainfo]General
Unique ID : 239493581812462171718278822642786306476 (0xB42CC93BE4271B6C8DB86FA03FF509AC)
Complete name : Love.And.Air.■■■.2013.720p.WEB-DL.H264-PublicHD.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 2.84 GiB
Duration : 1h 30mn
Overall bit rate : 4 472 Kbps
Encoded date : UTC 2014-02-04 11:45:40
Writing application : mkvmerge v6.7.0 ('Back to the Ground') 64bit built on Jan 8 2014 15:10:52
Writing library : libebml v1.3.0 + libmatroska v1.4.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 30mn
Bit rate : 3 999 Kbps
Width : 1 280 pixels
Height : 718 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.181
Stream size : 2.54 GiB (89%)
Language : English
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 1h 30mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 250 MiB (9%)
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 1
00:11:41.000 : en:Chapter 2
00:19:59.000 : en:Chapter 3
00:31:26.000 : en:Chapter 4
00:40:21.000 : en:Chapter 5
00:47:15.000 : en:Chapter 6
00:57:17.000 : en:Chapter 7
01:07:20.000 : en:Chapter 8
01:19:18.000 : en:Chapter 9
01:27:42.000 : en:Chapter 10[/mediainfo]
[mediainfo]General
Unique ID : 240427465372975882192109042980405584978 (0xB4E0A53F95FE0A679A4A152F6D932452)
Complete name : The.Art.Of.The.Steal.2013.720p.WEB-DL.H264-PublicHD.mkv
Format : Matroska
File size : 2.75 GiB
Duration : 1h 30mn
Overall bit rate : 4 367 Kbps
Encoded date : UTC 2014-02-07 11:48:20
Video
Format : AVC
Format profile : Main@L3.1
Duration : 1h 30mn
Bit rate : 3 896 Kbps
Height : 530 pixels
Display aspect ratio : 2.40:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.240
Stream size : 2.46 GiB (89%)
Language : English
Default : Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 1h 30mn
Bit rate : 384 Kbps
Bit depth : 16 bits
Stream size : 248 MiB (9%)
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:07:11.000 : en:Chapter 02
00:15:16.000 : en:Chapter 03
00:22:17.000 : en:Chapter 04
00:30:47.000 : en:Chapter 05
00:38:22.000 : en:Chapter 06
00:45:26.000 : en:Chapter 07
00:52:35.000 : en:Chapter 08
00:59:56.000 : en:Chapter 09
01:07:21.000 : en:Chapter 10
01:17:03.000 : en:Chapter 11
01:23:50.000 : en:Chapter 12[/mediainfo]
[mediainfo]General
Complete name : Charlie Wilson's War (2007).x264.AC3.DVDRip.720x460.mkv
Format : Matroska
Format version : Version 2
File size : 1.34 GiB
Duration : 1h 41mn
Overall bit rate : 1 883 Kbps
Encoded date : UTC 2012-01-04 18:59:30
Writing application : mkvmerge v5.1.0 ('And so it goes') built on Nov 28 2011 23:58:28
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format settings, CABAC : Yes
Format settings, ReFrames : 9 frames
Format settings, GOP : M=6, N=47
Muxing mode : Header stripping
Duration : 1h 41mn
Bit rate : 1 435 Kbps
Width : 720 pixels
Height : 460 pixels
Original display aspect ratio : 16:9
Color space : YUV
Bit depth : 8 bits
Stream size : 1 019 MiB (74%)
Writing library : x264 core 120 r2120 0c7dab9
Encoding settings : cabac=1 / ref=9 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1435 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=2:1.00
Language : English
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 1h 41mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Stream size : 327 MiB (24%)
Language : English[/mediainfo]
[mediainfo]General
Unique ID : 206591644118255567620793660908997842390 (0x9B6C1A763E5BBCC5B168EBC3127E15D6)
Complete name : 20.Feet.From.Stardom.2013.BDRip.x264-PHOBOS/20.Feet.From.Stardom.2013.BDRip.x264-PHOBOS.mkv
Format : Matroska
File size : 817 MiB
Duration : 1h 30mn
Overall bit rate : 1 260 Kbps
Encoded date : UTC 2014-02-07 08:04:36
Video
Format : AVC
Format settings, ReFrames : 5 frames
Duration : 1h 30mn
Width : 720 pixels
Height : 404 pixels
Color space : YUV
Bit depth : 8 bits
Writing library : x264 core 140 r2377 1ca7bb9
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=230 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Duration : 1h 30mn
Channel(s) : 2 channels
Channel positions : Front: L R
Delay relative to video : 9ms
Language : English
Default : Yes
Forced : No[/mediainfo]
Examples did not work
[mediainfo]General
Unique ID : 238912085820831981335297472251667800325 (0xB3BCCB449F2D50E4BD21FF81F92DE105)
Complete name : Megamind.2010.REPACK.576p.BDRip.DD5.1.x264-KinoLibre.mkv
Format : Matroska
File size : 1.73 GiB
Duration : 1h 35mn
Overall bit rate : 2 585 Kbps
Encoded date : UTC 2014-02-01 23:29:35
Writing application : mkvmerge v6.6.0 ('The Edge Of The In Between') built on Dec 1 2013 17:55:00
Video
Format : AVC
Format profile : High@L4.1
Format settings, ReFrames : 10 frames
Duration : 1h 35mn
Bit rate : 2 200 Kbps
Width : 1 024 pixels
Height : 432 pixels
Display aspect ratio : 2.35:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.207
Stream size : 1.43 GiB (83%)
Title : [R.G.KinoLibre]
Writing library : x264 core 92 r1510 33d382a
Encoding settings : cabac=1 / ref=10 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=2200 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 1h 35mn
Bit rate : 384 Kbps
Bit depth : 16 bits
Stream size : 263 MiB (15%)
Language : English
Text
Format : UTF-8
[mediainfo]General
Unique ID : 220643952955301543111595757795021007916 (0xA5FE7AC75B97C058A9E9CEBF6F21AC2C)
Complete name : The.Royal.Tenenbaums.2001.Criterion.576p.BluRay.x264.AC3-TBB.mkv
Format : Matroska
File size : 3.17 GiB
Duration : 1h 49mn
Overall bit rate mode : Variable
Overall bit rate : 4 134 Kbps
Encoded date : UTC 2012-08-14 06:00:14
Writing application : mkvmerge v5.7.0 ('The Whirlwind') built on Jul 8 2012 20:08:51
Video
Format : AVC
Format profile : High@L4.0
Format settings, ReFrames : 16 frames
Bit rate : 3 524 Kbps
Height : 426 pixels
Frame rate mode : Variable
Original frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Writing library : x264 core 125 r2208 d9d2288
Encoding settings : cabac=1 / ref=16 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / psy_rd=1.01:0.00 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=16.1 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=2:1.00
Language : English
Default : Yes
Forced : No
Audio #1
Format : AC-3
Codec ID : A_AC3
Duration : 1h 49mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Stream size : 352 MiB (11%)
Language : English
Default : Yes
Forced : No
Audio #2
Format : Vorbis
Format settings, Floor : 1
Codec ID : A_VORBIS
Duration : 1h 49mn
Bit rate mode : Variable
Bit rate : 80.0 Kbps
Stream size : 62.9 MiB (2%)
Title : Commentary with Director Wes Anderson
Writing library : aoTuV 20110424 (UTC 2011-04-24)
Language : English
Default : No
Forced : No
Text
Format : UTF-8
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Prologue: Family of Geniuses
00:06:54.080 : en:Cast of Characters: The Players
00:08:02.273 : en:Chapter One: 22 Years Later
00:16:41.375 : en:Chapter Two: Reunion of the Tenenbaum Children
00:27:05.457 : en:Chapter Three: A Pretty Bad Case of Cancer
00:35:13.945 : en:Maddox Hill Cemetery: The Salt of the Earth
00:42:11.237 : en:Chapter Four: Royal's Encyclopedias Are Placed in Storage
00:54:47.784 : en:Chapter Five: An Obsolete Vernacular
01:05:35.223 : en:Chapter Six: Between the Buttons
01:21:34.431 : en:Chapter Seven: Mordecai Comes Back
01:30:35.722 : en:Chapter Eight: Etheline and Henry's Wedding
01:41:28.582 : en:Epilogue: Bb Gun Salute[/mediainfo]
[mediainfo]General
Unique ID : 182641082018974648651262016411341359883 (0x89676494AC2B37E9A3684915419F0B0B)
Complete name : X:\Torrent\Rushmore.1998.Criterion.480p.Bluray.x264.AC3-TBB.mkv
Format : Matroska
File size : 2.25 GiB
Duration : 1h 33mn
Overall bit rate : 3 455 Kbps
Encoded date : UTC 2012-09-06 00:15:23
Video
Format : AVC
Format profile : High@L3.2
Duration : 1h 33mn
Bit rate : 2 858 Kbps
Width : 854 pixels
Height : 362 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.386
Stream size : 1.86 GiB (83%)
Encoding settings : cabac=1 / ref=16 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=13 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=14.1 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=2:0.75
Language : English
Default : Yes
Forced : No
Audio #1
Format : AC-3
Codec ID : A_AC3
Duration : 1h 33mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Stream size : 298 MiB (13%)
Language : English
Default : Yes
Forced : No
Audio #2
Format : Vorbis
Codec ID : A_VORBIS
Duration : 1h 33mn
Stream size : 53.2 MiB (2%)
Title : Commentary with Wes Anderson, Owen Wilson, and Jason Schwartzman
Writing library : libVorbis (Omnipresent) (20120203 (Omnipresent))
Language : English
Default : No
Forced : No
Text
Format : UTF-8
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Hardest
00:02:43.580 : en:Mr. Blume's Chapel Speech
00:04:41.531 : en:Yearbook Montage
00:05:53.853 : en:September: Sudden Death Academic Probation
00:09:13.678 : en:Rehearsal
00:13:12.333 : en:Harvard Is My Safety
00:16:05.506 : en:Rushmore Wrestling Squad
00:19:08.314 : en:Fishtank Scene
00:25:08.549 : en:Serpico
00:29:31.561 : en:Marine Observatory Fundraiser
00:33:37.599 : en:October: Grover Cleveland S.H.S.
00:38:25.303 : en:Max's Comeback
00:42:32.008 : en:Little Juan and 40 Ounce
00:48:22.566 : en:You Are Forgiven
00:52:50.793 : en:Summit With Dr. Guggenheim
00:56:33.765 : en:November: Eloise Fischer
01:00:03.642 : en:December: A Barber's Son
01:05:13.952 : en:War Does Funny Things to Men
01:09:47.183 : en:Remote Controlled Airplane Scene
01:12:31.973 : en:Perfect Attendance/Punctuality Awards
01:16:35.674 : en:Ready Demolition, Tucson, AZ
01:19:41.402 : en:January: Max's Latest Opus
01:25:17.738 : en:Heaven and Hell Cotillion
01:29:24.234 : en:End Credits[/mediainfo]
[mediainfo]General
Unique ID : 252819941414097090807344925922289665961 (0xBE33597D783566BFB670D785E16247A9)
Complete name : Top.Gun.1996.576.BDRip.x264-HANDJOB.mkv
Format : Matroska
Duration : 1h 49mn
Overall bit rate : 3 705 Kbps
Encoded date : UTC 2013-02-16 10:03:52
Writing application : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep 2 2012 15:37:04
Video
Format : AVC
Duration : 1h 49mn
Bit rate : 3 184 Kbps
Height : 432 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.300
Stream size : 2.44 GiB (86%)
Encoding settings : cabac=1 / ref=16 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=2.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=240 / rc=crf / mbtree=1 / crf=17.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.20
Language : English
Default : Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 1h 49mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Stream size : 351 MiB (12%)
Language : Engl
The green screen sympton sounds like a PMS issue with remuxing.
PlexConnect uses the native iOS player on the ATV so I would post your PMS logs and media info in the PMS forum and see if they can see what the problem is there; you may not see the same issue on iOS mobile devices if your PMS is transcoding instead of remuxing (due to a lower bitrate threshold - impossible to know for sure from the info you have posted here).
jpotenza, these mkv files will be remuxed for playback on the aTV. All the files that fail for you have an absurd amount of reference frames, between 10-16, no file on this planet needs that many reference frames, if I remember correctly the Level 4.1 H.264 spec only allows 4 or 5 reference frames at 1080p. So there is probably no way the atv will play a file with that many :frowning: Why people encode files with that many reference frames is beyond me as it’s not need and completely out of spec and only causes playback problems on lower powered devices.
If i go in plexweb to see the info from a movie but try to see the XML, it just shows up a blank page in safari nothing else.
So i cant put more information about my mkv in this topic;(
Or do you know how to fix the issue with XML?
Sent from my iPad using Tapatalk
you need to view the page source if you are viewing .xml in safari.
jpotenza, these mkv files will be remuxed for playback on the aTV. All the files that fail for you have an absurd amount of reference frames, between 10-16, no file on this planet needs that many reference frames, if I remember correctly the Level 4.1 H.264 spec only allows 4 or 5 reference frames at 1080p. So there is probably no way the atv will play a file with that many :( Why people encode files with that many reference frames is beyond me as it's not need and completely out of spec and only causes playback problems on lower powered devices.
Roidy,
I posted this on another forum and the ref-frames that you mentioned was what they stipulated as well.  Is there a way to force plex to transcode this into a more appropriate, less r-frame stream?  Or do you know of a way to that I can remux this quickly on my computer without the need to fully transcode, with no, to minimal loss in quality?
Yep, safari wont show you xml (not that it would give you any more info anyway) and the Media info that Plex provides is minimal at best. You need to run the files through a program like MediaInfo:- http://mediaarea.net/en/MediaInfo
Roidy,
Remuxing won't change the number of referance frames. In PlexConnect settings you can try changing "Transcoder Action" to "Transcode" to force the files to be transcoded and see if that works.
This worked great! Thank you, not sure why I didn't try it sooner.  Would be nice if I could keep Transcode on Auto and PlexConnect switched to Transcode with high ref-frame videos.  Anyways, this will work for now, thanks again!
Umm… PMS has an iOS-AppleTV.xml Profile that determines the playback capabilities of the aTV. I wonder if an UpperBound for the number of reference frames could be added to force a transcode.
Ok jpotenza, try this transcoder profile:- iOS-AppleTV.xml (1.71 KB)
On Windows it goes in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Profiles
On Mac  - Sorry don't use a mac so I don't really know. But at a guess just look in the location PMS is installed for a Resources\Profiles directory.
Back-up your original iOS-AppleTV.xml first and then copy in the replacement.
Not sure if PMS needs to be restarted but to be safe I would shut it down and restart it.
Now set the ATV back to AUTO transcode and see if the files now play ok.
In wich x.bundle did you find this ios-appletv.xml?
In Windows it's in the \Plex Media Server\Resources\Profiles directory. As I said in my post on Mac I have no idea as I don't have a Mac, but I would guess it's in the same \Resources\Profiles directory. I have no idea what an x.bundle is, sorry, I'm a PC only guy :)
On mac I typically goto here to manage the hidden pms settings such as adding bundles etc:
~/library/application support/plex media server/
But I don't see a resources directory.
Yep, wahlman.j that's the location it's says in this profiles thread:- https://forums.plex.tv/topic/73702-writing-profiles-for-dlna-devices/
Same for me wahlmanj., cant find the ressources folder
If you show package contents on the pms.app (in applications) by right clicking it there is a resources/profiles directory where the file in question is located at.
Nice wahlman.j :)
Great thanks wahlman.j
