Transcoding issue
I ran across 2 files that had 9 reference frames.  This was causing the transcoder to kick in (not a good thing on my Synology) so I edited the profile to change it from 8 to 9, and the files seem to play fine on my ATV3.  I'm not sure what the upper limit on what it supports, but it seem to be more than 8!
Actually the aTV only supports h.264 high profile level 4.0 which means it should only really support 4 reference frames at 1080p, but as you can see the aTV does in fact play files with a higher ref frame count. The problem is it also depends on a lot of other factors ie. bitrate and other encoder settings. So while one file with 9 ref frames might play fine another might not. If we set the ref frame count to high we end up with the same problem, files that just wont play and have no chance to be transcoded, and if we set it to low then files that don't need to be transcoded risk getting transcoded, which is a problem for people like you with low powered hardware. It's a difficult choice to make.
For me, I'd rather have it always try and direct play, and if that fails to play, then I force transcoding.  I do see what you're saying about what does the ATV officially support.  The file that I was watching was only 720p.  I don't suppose the profile can list what we support for 720p vs 1080p does it?
Also, I noticed that there is only 1 profile for ATV2 & ATV3, but they actually have different profiles
ATV3: High or Main Profile level 4.0
ATV2: Main Profile level 3.1
But not everybody wants the hassle of having to manually change the transcoder setting.
I think if the resolution is only 720p then more ref frames are supported. edit:- yep, aTV2 supports 5 ref frames at 720p and aTV3 supports 9 at 720p
Umm... not sure, I'll have to have a look at the xml profile again
Yep, currently only one profile, the aTV2 specs are even worse, Main@3.1 only supports 5 ref frames at 720p.
Hi PlexMembers,
I have an issue by watching the following movie on atv3: Get always a green screen:(
Does atv3 not support AVC codec?
General
Unique ID                        : 192830903437164029975998646866305475496 (0x9111E190A3F31270A2024994542DE3A8)
Complete name                    : /Volumes/LaCie/Downloads/Stirb.langsam.4.0.2007.German.DTS.DL.1080p.BluRay.AVC.Remux-LeetHD/lhd-stirb4-rmx.mkv
Format                           : Matroska
File size                        : 26.3 GiB
Duration                         : 2h 8mn
Overall bit rate                 : 29.3 Mbps
Encoded date                     : UTC 2011-04-07 10:47:14
Writing application              : mkvmerge v4.4.0 ('Die Wiederkehr') gebaut am Oct 31 2010 21:52:48
Writing library                  : libebml v1.0.0 + libmatroska v1.0.0
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 2 frames
Muxing mode                      : Header stripping
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 2h 8mn
Bit rate mode                    : Variable
Bit rate                         : 26.4 Mbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 16:9
Frame rate                       : 23.976 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.531
Stream size                      : 23.7 GiB (90%)
Audio #1
Format                           : DTS
Format/Info                      : Digital Theater Systems
Codec ID                         : A_DTS
Duration                         : 2h 8mn
Bit rate mode                    : Constant
Bit rate                         : 754 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Sampling rate                    : 48.0 KHz
Bit depth                        : 24 bits
Compression mode                 : Lossy
Stream size                      : 695 MiB (3%)
Language                         : German
Audio #2
Format                           : DTS
Codec ID                         : A_DTS
Duration                         : 2h 8mn
Bit rate                         : 1 510 Kbps
Bit depth                        : 24 bits
Stream size                      : 1.36 GiB (5%)
Language                         : English
Text
Format                           : VobSub
Muxing mode                      : zlib
Codec ID                         : S_VOBSUB
Codec ID/Info                    : The same subtitle format used on DVDs
Language                         : German
No, aTV will play AVC fine, AVC is just another name for h.264/mpeg4. I suspect there is something else wrong with the file, try remuxing it with a program like subler or iFlicks.
 ok thanks.
Will try with remux for os x.
Cant figure out how subler works..
Thx
Remux doesn't work :(
Cant figure out what the issue of the mkv file is.
Just get green Screen on atv3.
In Vlc it works fine but in Mplayer X it is pixeled :(
Nobody knows a good software to reencode movie or something like this.. i don't wanna loose quality of the movie and sound.
any Ideas?
File that doesn't work:
Format                           : Matroska
Duration                         : 2h 8mn
Video
Format                           : AVC
Duration                         : 2h 8mn
Color space                      : YUV
Bit depth                        : 8 bits
Audio #1
Format                           : DTS
Codec ID                         : A_DTS
Duration                         : 2h 8mn
Bit rate                         : 754 Kbps
Bit depth                        : 24 bits
Language                         : German
Audio #2
Format                           : DTS
Codec ID                         : A_DTS
Duration                         : 2h 8mn
Bit depth                        : 24 bits
Language                         : English
Text
Format                           : VobSub
Muxing mode                      : zlib
Codec ID                         : S_VOBSUB
Language                         : German
Menu
00:00:00.000                     : de:Chapter 01
00:03:53.149                     : de:Chapter 02
00:06:18.544                     : de:Chapter 03
00:07:49.135                     : de:Chapter 04
00:11:31.524                     : de:Chapter 05
00:15:16.081                     : de:Chapter 06
00:17:57.493                     : de:Chapter 07
00:20:47.496                     : de:Chapter 08
00:25:55.887                     : de:Chapter 09
00:27:30.106                     : de:Chapter 10
00:30:02.884                     : de:Chapter 11
00:31:27.719                     : de:Chapter 12
00:33:47.066                     : de:Chapter 13
00:38:16.294                     : de:Chapter 14
00:41:04.253                     : de:Chapter 15
00:45:42.865                     : de:Chapter 16
00:52:16.133                     : de:Chapter 17
00:55:26.573                     : de:Chapter 18
00:58:02.312                     : de:Chapter 19
01:00:47.060                     : de:Chapter 20
01:02:29.871                     : de:Chapter 21
01:08:15.508                     : de:Chapter 22
01:12:31.263                     : de:Chapter 23
01:17:01.199                     : de:Chapter 24
01:18:28.161                     : de:Chapter 25
01:21:30.051                     : de:Chapter 26
01:25:52.063                     : de:Chapter 27
01:32:45.101                     : de:Chapter 28
01:36:50.012                     : de:Chapter 29
01:39:47.523                     : de:Chapter 30
01:45:02.254                     : de:Chapter 31
01:46:22.459                     : de:Chapter 32
01:51:21.174                     : de:Chapter 33
01:56:38.700                     : de:Chapter 34
01:58:12.543                     : de:Chapter 35
02:01:44.213                     : de:Chapter 36
02:08:44.466                     : de:Chapter 37
Hi PlexMembers,
Video
Format                           : AVC
It's a High@L4.1 file, the ATV only supports High@L4.0.  Likely the bitrate is too high for it to handle.
ok thanks, but these 2 movies got High@L4.1 and High@L5.0
Theses are working just fine
Format                           : AVC
Format settings, ReFrames        : 5 frames
Duration                         : 2h 11mn
Bit rate                         : 4 818 Kbps
Height                           : 808 pixels
Display aspect ratio             : 2.35:1
Color space                      : YUV
Video
Format                           : AVC
Format profile                   : High@L5.0
Duration                         : 1h 27mn
Bit rate                         : 4 914 Kbps
Frame rate mode                  : Variable
Color space                      : YUV
Bit depth                        : 8 bits
Bits/(Pixel*Frame)               : 0.099
Your one that doesn't play has a bitrate of 26.4mbit, these 2 are less than 5mbit.
Ok thanks;) could you please tell me whats the differences between those bitrates? And how can i reduce the bitrate of the mkv file? Without loosing quality:/ App?
Whats the best bitrate for full hd 1080p movies?
Thx in advance;)
Edit:
This file also works on atv3 but has a nitrate of 24.2Mbit
Unique ID                        : 196843114238888683914899555101479162919 (0x94169AD48F698BA8ADB75E5287765427)
Complete name                    : /Volumes/LaCie/High Definition/Marvels.The.Avengers.German.AC3.BDRip.XviD-EPHEMERiD/rhd-mta-rmx.mkv
Format                           : Matroska
File size                        : 30.8 GiB
Duration                         : 2h 22mn
Overall bit rate                 : 30.8 Mbps
Encoded date                     : UTC 2012-08-30 13:00:28
Writing application              : mkvmerge v4.8.0 ('I Got The...') gebaut am May 24 2011 03:12:58
Writing library                  : libebml v1.2.0 + libmatroska v1.1.0
Video
Format                           : AVC
Format settings, ReFrames        : 4 frames
Muxing mode                      : Container profile=Unknown@0.0
Duration                         : 2h 22mn
Bit rate                         : 24.2 Mbps
Maximum bit rate                 : 32.0 Mbps
Color space                      : YUV
Bit depth                        : 8 bits
Bits/(Pixel*Frame)               : 0.487
Stream size                      : 24.2 GiB (79%)
Edit 2:
.:) i found a way to play them without issues on atv3.
Set Transcoder to transcode on atv3 .)
