Transcoding with intel uhd 730
Server Version#: 1.32.8.7639
Player Version#: various
Plex doesn’t seem to be transcoding with my integrated gpu. it seems this broke somewhere around version 1.25x.
Is it still broken? If not, is there something I have to do to get it to work?
My PMS is running in a docker on a unRaid server.
TIA
Which CPU?
Which Plex docker image and what does your docker setup look like?
Do you have this line on the “Extra Parameters” line of the docket setup info?
–device=/dev/dri
Did you install these 2 plugins?
-Intel GPU TOP
-GPU Statistics
I have an i5-12600k working just fine (UDH 770) for hardware transcoding w/Plex in Unraid, using the linuxserver image.
I’ve just installed those plugin. Now I have to wait for an opportunity to transcode something.
Thanks.
