Translation German
why is in the german version the Library in the Plex Server settings called „Zuletzt hinzugefügte Filme“ but in the start screen „Recently added in Filme“?
Latest Plex Server on Synology NAS
Latest Version of Plex on Android TV.
Best regards.
The hub in the home screen is a relatively new one and simply hasn’t had a fitting translation available, before it was rolled into a server release.
This will change over the course of the next server releases.
thx Otto, i will be patient :smiley:
Hi @OttoKerner,
the translation isn’t correct until now. Do you know when it will be fixed?
Best Regards
You will have to wait until the server version which is currently in Beta becomes available publicly.
thanks for the answer :slight_smile:
