Transmogrify for Plex: A browser extension that adds features to Plex/Web
I've pushed out v0.2.1 which should help with some possible hanging issues. Let me know if that runs better for you.
@ moussa
unfortunately it's still freezing.  i've never submitted a log file before, so if you can explain where i may find one for the webui/extensions(?) i'd be happy to help you with this.
enabled it freezes, disabled everything works as expected so it does appear to be directly related.
is the update causing anyone else to suffer from a hung page?  links aren't clickable and the page refresh appears to freeze after displaying the full standard page layout for film & tv - whilst not showing the plex-y / transmogrify additional content.
when i disable the extension everything is working as expected.
i'm using chrome browser on a win7 machine.
Tried the extension for the first time today and also experiencing something similar. When I open a movie/series page the page becomes extremely slow. Turning off the extension makes everything work fine again.
gas, drzoidberg33: I've pushed v0.2.2 which adds a debug log to the console. Enable debugging on the options page, open the console on the plex.tv page (ctrl-shift-j) and reload the page. Can you copy the whole output of the console when the page freezes and send it to me in a private paste please? Thanks
Edit: I've also made some changes that may or may not help with the freezing issues.
i use letterboxd quite a lot, its enabled.. but wheres the link on the movie page on plex?
It can be found here
weird.. mines blank?
Ah, I think it may be because you're not using the default metadata agent for movies. It only works with the default agent at the moment because that is the only agent that gives me the imdb id, which is the most reliable way to get the letterboxd link. I will look into the other agents in the near future.
Edit: Which agent are you using btw?
TMBD. The Movie Database
Just a sec.
There you go. I just pushed out an update that supports that agent. I didn't realize letterboxd supported tmdb ids so it was easy enough to add support.
Just a sec.
It works now, thank you for this great chrome extension.
moussa … as instructed i’ve copied the console output onto a text file (it’s probably not that big but too big for an easy forum read). hope this helps…
http link removed temporarily pending a security edit
Ok so from your logs several things stick out to me. You have other peoples libraries shared with you and some of them are unreachable. I think what's happening is the extension is picking the wrong server to try to fetch data from. I'll look into this but it's a bit harder for me to reproduce as I only have one server, but I have ideas.
Edit: Ok I think I'm gonna need someone to share their library with me so I can figure this out properly. Any volunteers?
Double edit: Can someone with the freezing issues uninstall the extension and install this beta version and see if it solves it?
That works a lot better.
Great! I assume you have shared libraries too? Can you make sure the random show/movie picker is working properly in particular please.
It seems to work fine on my own Server. In my Movie collection it chooses a random movie and in my tv shows section it chooses a random show.
But I just discovered that if I go to a shared library and try to click on the Pick Random nothing happens and when i go into a movie on a shared library then the trailer and Letterboxd button does not show.
Okay I'll look into this. Could you turn on logging, reload the site, then click on the random button and visit a shared movie page, and then send me the log? In a PM please.
I am not at a PC right now but when I am home i will try. Where are the log placed?
Sendt fra min Nexus 7 med Tapatalk
I don't think you'll need to now, I think I've fixed the issue. Try updating the beta extension now and trying it out.
Yes. Now it seems to work. In shared and in the local.
