Tv show downloads not grouping
hi i have seen this issue have been around for almost a year is there any plan on fixing it. I don’t use my android table that much so I only find out about the problem since September so i just ignored it thinking there will be a update soon to fix it. now i have been reading that its been a problem since April and still no fix. my problem is the when i download it shows up as individual episode and that you can’t just download all season at once you have to do each season separate.
I also have the same issue and would love to have this fixed.
Same I would love to have this finally implemented
You can Download a Season at once but must be from a Season Poster's listed tool bar /Download. Likewise from a Episode for just an Episode.
Alternatively from PMS in the same manner Season Poster Vertical Ellipsis ⋮, bottom Left on a Poster.
The issue of Episode downloads being arranged in a Library format has been discussed many times and hopefully will be implemented as development of Experience apps continues.
