TV Shows missing
I have shows on my hard drive but they are not showing at all on PLEX tv show menu
Can i just add to my own post, what is the point to PLEX now. paid subscription but all i get is more posts to paid content or advert content and not my own library!!
Problems are caused by poorly named media, especially your folder structure.
If you correctly name all your media as per Naming and Organizing Your TV Show Files | Plex Support then all of these problems will be go away.
Now it’s really up to you what you do next. You might want to complain and say well it should just detect everything but ultimately that’ll get you nowhere. Renaming will :+1:
@Stevoc19 I have completely disabled Plex’s online media sources and dont see any of that. Plex works great if you understand how to structure your library.
Dont:
  • Throw all your TV in 1 folder and make plex try to figure out what you are doing.
  • Have a folder per episode
  • ignore the file naming recommendations
Do:
and my canned response:
If you want to save yourself a lot of time I would recommend using Download - tinyMediaManager and use below as the new name format.
filename
${showTitle} - S${seasonNr2}E${episodeNr2} - ${title}
foldername
${showTitle} (${showYear}) {tvdb-${tvShow.ids.tvdb}}
