TVDB Media Scanner not working anymore since update to 1.14.1.5488 (movie scanner works)
Server Version#: 1.14.1.5488
Player Version#: 3.77.2
Plex Server is running on Ubuntu 18.04
Plex Client on Mac OSX 10.14.1
When i add a new TV Series or fresh metadata I am getting this message since the last server update but only for TV.
Dec 26, 2018 06:09:49.676 [0x7ff6acbff700] DEBUG - [com.plexapp.agents.thetvdb] Plug-in is starting, waiting 1 seconds for it to complete.
Dec 26, 2018 06:09:51.353 [0x7ff6acbff700] ERROR - [com.plexapp.agents.thetvdb] Plug-in took too long to start, returning error.
Dec 26, 2018 06:09:51.353 [0x7ff6a83fb700] DEBUG - [com.plexapp.agents.thetvdb] Plug-in is starting, waiting 180 seconds for it to complete.
Dec 26, 2018 06:09:51.354 [0x7ff6da3ff700] DEBUG - Completed: [127.0.0.1:33024] 500 GET /:/plugins/com.plexapp.agents.thetvdb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo2CnMyCmVuczQKbGFuZ2IwczYKbWFudWFsYjFzNwpwcmltYXJ5aTAKczcKdmVyc2lvbnIxCnM2Cmt3YXJnc3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZTkKczE2CmM1NjM4MzRjM2U5YTU2MjhzMTcKb3BlblN1YnRpdGxlc0hhc2hzMgoxM3M3CmVwaXNvZGVzMQoxczgKZXBpc29kaWNzMTIKQm9zdG9uIExlZ2FsczQKc2hvd3MxCjVzNgpzZWFzb25zMTE5CiUyRm1lZGlhJTJGcW5hcDQlMkYxJTJGc29uYXJyJTJGQm9zdG9uJTIwTGVnYWwlMkZTZWFzb24lMjA1JTJGQm9zdG9uJTJFTGVnYWwlMkUtJTJFUzA1RTEzJTJFLSUyRUxhc3QlMkVDYWxsJTJFKDIpJTJFbWt2czgKZmlsZW5hbWVzNDAKNzg2YWZkZmU5YTM3NTA4OGM2NWM2NWIxNzk4NzA2NTVhN2E5MTU3NnM4CnBsZXhIYXNoczIKLTFzOApkdXJhdGlvbnM1CjUzMDk1czIKaWRyMAo_ (28 live) GZIP 1448601ms 376 bytes
Dec 26, 2018 06:09:52.706 [0x7ff6a83fb700] DEBUG - [com.plexapp.agents.thetvdb] Plug-in is starting, waiting 179 seconds for it to complete.
Dec 26, 2018 06:09:54.413 [0x7ff6a83fb700] DEBUG - [com.plexapp.agents.thetvdb] Plug-in is starting, waiting 178 seconds for it to complete.
Dec 26, 2018 06:09:55.826 [0x7ff6a83fb700] DEBUG - [com.plexapp.agents.thetvdb] Plug-in is starting, waiting 177 seconds for it to complete.
Dec 26, 2018 06:09:57.652 [0x7ff6a83fb700] DEBUG - [com.plexapp.agents.thetvdb] Plug-in is starting, waiting 176 seconds for it to complete.
Dec 26, 2018 06:09:59.010 [0x7ff6c9ffe700] ERROR - Error issuing curl_easy_perform(handle): 28
Dec 26, 2018 06:09:59.010 [0x7ff6c9ffe700] DEBUG - HTTP simulating 408 after curl timeout
Dec 26, 2018 06:09:59.011 [0x7ff6c9ffe700] ERROR - Error parsing content.
Dec 26, 2018 06:09:59.011 [0x7ff6c9ffe700] ERROR - Exception caught while attempting to match metadata on item 52902: Error parsing file
Dec 26, 2018 06:09:59.011 [0x7ff6c9ffe700] ERROR - XML was (0 bytes):
Dec 26, 2018 06:09:59.012 [0x7ff6da3ff700] DEBUG - Completed: [127.0.0.1:36438] 200 GET /library/metadata/52902/matches?agent=com.plexapp.agents.thetvdb&language=en&manual=0 (28 live) GZIP 300352ms 453 bytes
curl gets a timeout but why? How can i debug this? Or does anyone have a solution?
EDIT:
in PMS\ Plugin\ Logs/com.plexapp.system.log i also see
2018-12-26 06:45:42,342 (7f447ffff700) : ERROR (networking:219) - Error opening URL ‘http://127.0.0.1:32400/:/plugins/com.plexapp.agents.thetvdb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo2CnMyCmVuczQKbGFuZ2IwczYKbWFudWFsYjFzNwpwcmltYXJ5aTAKczcKdmVyc2lvbnIxCnM2Cmt3YXJnc3M3ClRWX1■■■3dzMTAKbWVkaWFfdHlwZTkKczE2Cjk2MTcyOGI0ZjdjY2MyYTZzMTcKb3BlblN1YnRpdGxlc0hhc2hzMgoxMHM3CmVwaXNvZGVzMQoxczgKZXBpc29kaWNzOApNciBSb2JvdHM0CnNob3dzMQozczYKc2Vhc29uczExMAolMkZtZWRpYSUyRnFuYXA0JTJGMSUyRnNvbmFyciUyRk1yJTJFJTIwUm9ib3QlMkZTZWFzb24lMjAzJTJGTXIlMkVSb2JvdCUyRS0lMkVTMDNFMTAlMkUtJTJFc2h1dGRvd24lMkUtciUyRW1rdnM4CmZpbGVuYW1lczQwCmVmM2JjY2ZlN2RiNGQ2OGFmZmVlNDA2OTdkNTY5NzBmOTA5MjY2NzRzOApwbGV4SGFzaHM3CjM0NjcyNjRzOApkdXJhdGlvbnM1CjUyOTAyczIKaWRyMAo_
curl gets to the URL… so this is not the problem
curl http://127.0.0.1:32400/:/plugins/com.plexapp.agents.thetvdb/messaging/function/
Unauthorized
401 Unauthorized
I’ve got the same error
end than it’s trying again for three minutes without results. Can’t know the reason for it though.
  1. Accessing the server requires your “PlexOnlineToken” be added to all curl queries of your server. This is how security it performed. You add &X-Plex-Token=<token_value_here>
  2. May I see full DEBUG logs (ZIP) ?
I am also having the same error. I will attach my logs.
Plex Media Server Logs_2019-03-09_14-42-11.zip (6.1 MB)
Any help would be appreciated. Checking changelogs to see if beta versions of this platform have the fix. Thanks!
two things:
  1. 1.15.0 is now out
  2. Before doing anything, I recommend deleting all you find under "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Caches"
  3. Force rescan of all your files.
