Tvolucion - Xpath Problem
Hi my name is Juan Carlos is my first post but in this moment I develop a plugin for Plex!!! :slight_smile:
All plugin is finished but I have problem with a xpath, look is this the code…
urlCapitulo = forElementos.xpath(’./img[@onClick]’).text
I want parse from this line:
  • Teresa
    Listos para la boda
    Duración: 00:43:53
    Capítulo: 90
  • I need get the content from onClick
    onClick=“GoLink(this, ‘http://tvolucion.esmas.com/telenovelas/drama/teresa/091281/teresa-capitulo-90/ipad’);”
    the link: http://tvolucion.esmas.com/telenovelas/drama/teresa/091281/teresa-capitulo-90/ipad
    How i get with xpath.
    Thanks so much
    JC
    try:
    <br />
    urlCapitulo = forElementos.xpath('./img').get('onClick')<br />
    Jonny
    And after the xpath you’d need to extract the url from the returned string. You can of course use a regular expression for this, but in this case you can also use a simple split and split the string on the single quote. This will return a list with 3 elements:
    0 = GoLink(this, <br />
    1 = http://tvolucion.esmas.com/telenovelas/drama/teresa/091281/teresa-capitulo-90/ipad<br />
    2 = );
    So use this:
    urlCapitulo = urlCapitulo.split("'")[1]
    Thanks for the answers, look I have another trouble, that is my last line to get finish the plugin!!!
    urlCapitulo = forElementos.xpath('//img')[0].get('onClick')
    urlCapitulo = urlCapitulo[0]
    If don't use the [0] in forElementos.xpath('//img')[0].get('onClick') don't run, but if use this code, the second line urlCapitulo = urlCapitulo.split("'")[1] doesn't works
    Please help me, thank you
    The error code is:
    12/12/10 04:21:44 [0x0-0x783783].com.plexapp.plexmediaserver[12929] File "/Users/JC/Library/Application Support/Plex Media Server/Plug-ins/Tvolucion.bundle/Contents/Code/__init__.py", line 121, in videoIpad
    It looks like the xpath isn’t returning a string that can be split into three pieces. Couple of things; first, the xpath predicate in your last message
    //img
    is different from that suggested
     ./img
    . The one you posted will get all img tags in the whole document.The other will get children of forElementos.
    Second, try using Log to print out the string returned from get to see if it can be split.
    Jonny
    Hi I try with the ./img but is the same problem, because when I put the log the fetch is none. Any suggest?
        MediaContainer.art = (arte)<br />
        dir = MediaContainer(programa=sender.itemTitle)<br />
        dir.viewGroup = 'InfoList'<br />
        contenidos = XML.ElementFromURL(urlCapitulo, True)<br />
        for forElementos in contenidos.xpath('//div[@id="grid_cont"]/ul/li'):<br />
          vidUrl = contenidos.xpath('./img').get('onClick')<br />
          Log(tituloCapitulo)<br />
          vidUrl = tituloCapitulo.split("'")[1]<br />
          imagenCapitulo = forElementos.xpath('./img')[0].get('src')<br />
          numeroCapitulo = forElementos.xpath('./h3')[2].text[10:]<br />
          tituloCapitulo = forElementos.xpath('./h3')[0].text<br />
          sumarioCapitulo = forElementos.xpath('//h3')[0].text<br />
          duracionCapitulo = forElementos.xpath('./h3')[1].text<br />
          dir.Append(WebVideoItem(PREFIJO_FLASH, summary=vidUrl + sumarioCapitulo + "
    " + duracionCapitulo, thumb=imagenCapitulo, title=numeroCapitulo + ". " + tituloCapitulo))<br />
        return dir<br />
    There’s a number of things in that code that look a little odd.
    <br />
    should be operating on the current iterator element, no? i.e.
    <br />
    vidUrl = forElementos.xpath('./img').get('onClick')<br />
    Then, both your Log statements are working on a variable that hasn't been initialized - it happens later in the loop - so will be None
    And the split is also operating on the same non-initialized variable, and you should be splitting the string with a comma not an apostrophe
    <br />
    vidUrl = vidUrl.split(",")[1]<br />
    and then your WebVideoItem is using the same video URL for every entry, PREFIJO_FLASH. Don't you want vidUrl there?
    Jonny
    Hey Jonny I fixed the error this is the most stupid error
    urlVideo = forElementos.xpath("./img")[0].get('onclick')
    urlVideo = urlVideo.split("'")[1]
    I write onClick and the correct is onclick
    well I finished :) in some hours I will upload the plugin, but I have a question, how I insert the video when the format is mp4, you need the: http://www.plexapp.com/player/player.php?clip=
    Thanks!
    If it's an .mp4 video file, you don't need to use WebVideoItem or www.plexapp.com/player.php... (those are used for Flash/Silverlight content)
    try this:
    dir.Append(VideoItem(PREFIJO_FLASH, summary=vidUrl + sumarioCapitulo + "
    Glad you got it.
    Is the video URL you have directly to an mp4 file? If so, they are the easiest to deal with. Just use VideoItem instead of WebVideoItem with the mp4 URL as the target.
    Is this plugin ready ? Did you get to finish it ?
    Sorry for the time, just only I have some issues because Tvolucion, change some lines of code and this plugin is parsing html.
    Please give me some days I recode the plugin.
    Only some issues from this plugin:
    • Some section (or maybe all) have a problem with the “In your country you don’t play this video”. Is possible just USA, because have an agreement with Telemundo.
    • Only works 4 of 15:
      The most recent
      iPad Version (HD)
      Foro TV (Discussion Threads)
      News
      Talk Soups
      If I upload the plugin could get feedback, ideas, bug fixes, and for the Plex Online
    Ok it’s the first version of TVolucion’s Plugin, some sections don’t have data because some videos was coded with a propietary format and any type of app wasn’t played, the format is QVT.
    Well plz take ma back a feedback is my first app, not only on Plex, is on Phyton :)!
    Sorry I forgot upload the file.
    disculpa juan carlos soy nuevo en plex mac, como le puedo hacer para ver netflix en plex no encuentro algun tutorial o manera de instalar los plugins crees que sea molestia me expliques que hacer?
    gracias :brian cano
    no funciona el plug in o es que lo instalo mal???
