I’m trying to use the quadhd on debian stretch kernel 4.9 but the card is not showing up in dvr beta.
I do have the latest plex version (Version 1.7.3.3937)
the card is showing up under lspci -v
! 04:00.0 Multimedia video controller: Conexant Systems, Inc. CX23885 PCI Video and Audio Decoder (rev 04)
! Subsystem: Hauppauge computer works Inc. CX23885 PCI Video and Audio Decoder
! Flags: bus master, fast devsel, latency 0, IRQ 18
! Memory at f7600000 (64-bit, non-prefetchable) [size=2M]
! Capabilities: [40] Express Endpoint, MSI 00
! Capabilities: [80] Power Management version 2
! Capabilities: [90] Vital Product Data
! Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
! Capabilities: [100] Advanced Error Reporting
! Capabilities: [200] Virtual Channel
! Kernel driver in use: cx23885
! Kernel modules: cx23885
! 05:00.0 Multimedia video controller: Conexant Systems, Inc. CX23885 PCI Video and Audio Decoder (rev 04)
! Flags: bus master, fast devsel, latency 0, IRQ 19
! Memory at f7400000 (64-bit, non-prefetchable) [size=2M]
as I heared the drivers are included in the kernel since 4.4, aren’t they? So what do I have to do that this card is showing up under DVR (beta)
I found the ppa provided by Hauppauge. But as it looks they supply modified linux kernels (4.10, 4.8 and 4.6). They wont fit with my Kernel 4.9 delivered with debian stretch. Is the source code available so I can compile it myself?
Thanks a lot
