What you should do (best) would be avoid HEVC content. H.264 content only.
In case of mounting a latest generation CPU, if there is no beignet-opencl-icd, it can be a problem in that case, right?
For you, beignet not being there does not matter at all.
Would you please open a terminal window and type this command for me?
sudo /var/lib/dpkg/info/plexmediaserver.preinst
Next, Please get the contents of /tmp/plexinstaller.log and share that here (use </> code formatting button)
[chuck@lizum ~.2002]$ cat /tmp/plexinstaller.log
# Plex Media Server installation configuration info: Mon 02 May 2022 04:18:31 PM EDT
Init=0
Systemd=1
Custom=0
LinuxContainer=0
NewInstall=0
HaveOverride=0
OverrideFile=""
PlexUser="plex"
PlexGroup="plex"
VideoGroup="render"
AppSuppDir="/var/lib/plexmediaserver/Library/Application Support"
PlexTempDir="/tmp"
LangEncoding="en_US.UTF-8"
ExistingVersion=12600
HaveHardware=1
HaveTranscoderPref=0
NeedUser=0
NeedGroup=0
NeedVideo=0
Verbose=1
Running=0
Errors=0
Warnings=0
HaveIntel=1
HaveIntelCore=1
HaveIntelXeon=0
Havei915=1
HaveNvidia=0
Processor=Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
CPUSKU=8809
NeedOpenCL=1
NeedBeignet=1
NeedIntelCompute=0
HaveIntelGmmlib=0
HaveIntelIGCCore=0
HaveIntelIGCOpenCL=0
HaveIntelOpenCL=0
HaveIntelCompute=0
HaveBeignet=1
HaveOpenCL=1
Platform="NUC8i7HVK"
Processor="Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz"
Distro="Ubuntu 20.04.4 LTS"
Kernel="Linux lizum 5.13.0-40-generic #45~20.04.1-Ubuntu SMP Mon Apr 4 09:38:31 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux"
Memory="64232 7915 21696"
[chuck@lizum ~.2003]$
Here I attach the two commands I hope to be able to help in everything that is in my hands.
$ sudo /var/lib/dpkg/info/plexmediaserver.preinst
PlexMediaServer install: Pre-installation Validation.
PlexMediaServer install: Pre-installation Validation complete.
# Plex Media Server installation configuration info: mar 03 may 2022 09:02:53 CEST
Init=0
Systemd=1
Custom=0
LinuxContainer=0
NewInstall=0
HaveOverride=0
OverrideFile=""
PlexUser="plex"
PlexGroup="plex"
VideoGroup="render"
PlexTempDir="/tmp"
ExistingVersion=12601
HaveHardware=1
NeedUser=0
NeedGroup=0
NeedVideo=0
Verbose=1
Running=1
Errors=0
Warnings=0
HaveIntel=1
HaveIntelCore=1
HaveIntelXeon=0
Havei915=1
HaveNvidia=0
Processor=Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz
CPUSKU=4440
NeedOpenCL=1
NeedBeignet=1
NeedIntelCompute=0
HaveIntelGmmlib=0
HaveIntelIGCCore=0
HaveIntelOpenCL=0
HaveIntelCompute=0
HaveBeignet=0
HaveOpenCL=1
Platform="To Be Filled By O.E.M."
Processor="Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz"
Distro="Ubuntu 22.04 LTS"
Kernel="Linux 5.15.0-27-generic #28-Ubuntu SMP Thu Apr 14 04:55:28 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux"
Memory="15660 826 12792"
Thank you for getting this.
I need to fix this: CPUs without HW HDR capability should not be "Need"ing Beignet/OpenCL.
If I can help more, donāt hesitate to ask me.
Also note that for CPUs that support beignet-opencl-icd this library is not available in the latest version of ubuntu, only Intel-opencl-icd is available.
Would it be better to use the plex .deb or plex installation in docker?
@ChuckPa fyi⦠I upgraded to plexmediaserver_1.27.0.5873-8f821a871_amd64.deb and noticed that beignet-opencl-icd is reported as a recommended package ā¦
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Note, selecting 'plexmediaserver' instead of '/data/Personal/Software/ubuntu/plexmediaserver_1.27.0.5873-8f821a871_amd64.deb'
Recommended packages:
beignet-opencl-icd
The following packages will be upgraded:
plexmediaserver
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/83.7 MB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 /data/Personal/Software/ubuntu/plexmediaserver_1.27.0.5873-8f821a871_amd64.deb plexmediaserver amd64 1.27.0.5873-8f821a871 [83.7 MB]
(Reading database ... 241677 files and directories currently installed.)
Preparing to unpack .../plexmediaserver_1.27.0.5873-8f821a871_amd64.deb ...
Unpacking plexmediaserver (1.27.0.5873-8f821a871) over (1.27.0.5849-99e933842) ...
Setting up plexmediaserver (1.27.0.5873-8f821a871) ...
PlexMediaServer install: PlexMediaServer-1.27.0.5873-8f821a871 - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install: Installation Type: Update
PlexMediaServer install: Process Control: systemd
PlexMediaServer install: Plex User: plex
PlexMediaServer install: Plex Group: plex
PlexMediaServer install: Video Group: render
PlexMediaServer install: Metadata Dir: /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install: Temp Directory: /tmp
PlexMediaServer install: Lang Encoding: en_US.UTF-8
PlexMediaServer install: Intel i915 Hardware: Not found
PlexMediaServer install: Nvidia GPU card: Found
PlexMediaServer install: Completing final configuration.
PlexMediaServer install: Starting Plex Media Server.
PlexMediaServer install: PlexMediaServer-1.27.0.5873-8f821a871 - Installation successful. Errors: 0, Warnings: 0
Processing triggers for desktop-file-utils (0.26-1ubuntu3) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu3) ...
Processing triggers for mailcap (3.70+nmu1ubuntu1) ...
Full install log below ā¦
# Plex Media Server installation configuration info: Mon 06 Jun 2022 15:19:11 IST
Init=0
Systemd=1
Custom=0
LinuxContainer=0
NewInstall=0
HaveOverride=0
OverrideFile=""
PlexUser="plex"
PlexGroup="plex"
VideoGroup="render"
PlexTempDir="/tmp"
ExistingVersion=12700
HaveHardware=1
NeedUser=0
NeedGroup=0
NeedVideo=0
Verbose=1
Running=1
Errors=0
Warnings=0
HaveIntel=1
HaveIntelCore=1
HaveIntelXeon=0
Havei915=0
HaveNvidia=1
Processor=Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
CPUSKU=9750
NeedOpenCL=0
NeedBeignet=0
NeedIntelCompute=0
HaveIntelGmmlib=0
HaveIntelIGCCore=0
HaveIntelOpenCL=0
HaveIntelCompute=0
HaveBeignet=0
HaveOpenCL=1
Platform="81UJ"
Processor="Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz"
Kernel="Linux dokuro 5.15.0-35-generic #36-Ubuntu SMP Sat May 21 02:24:07 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux"
Memory="32019 8751 342"
This package should not be needed in my situation as Iām running a dedicated nvidia gpu and donāt have a intel gpu.
I have updated the packaging.
Here is the preview thread.
These changes have been submitted to QA for inclusion by Engineering.
Thanks. Do remember the other thread but didnāt check its full detail as it had moved on from the last I looked.
Thanks again.
Did it move without my permission?
