Unable to connect server after plexpass upgrade and container restart
Wonder if someone can help me out here. I run plex using the plexinc/pms-docker image with the latest build. earlier today I purchased the lifetime plexpass and did my usual image pull and recreated the container. After that I’m unable to reach my server at all. when I look at the container it lists as healthy instead of running and the logs show “Critical: libusb_init failed” after the server starts. I’ve installed it on both and the host and interactively inside the container but still nothing. Can anyone advise? I’ve changed no other settings and never had an issue with updates. I’ve also tried older builds as well.
This error can be ignored as it relates to PMS trying scan the USB ports for TV tuners.
I suggest that you post the contents of either your docker-compose.yml file or the docker command you used to create the container.
We can’t assist with troubleshooting with no information provided.
