Unable to record radio stations via HdHomeRun/PVR
I’m on 1.7.2.3878, PVR enabled with a HDHomeRun (UK Freeview). Recording TV (SD/HD) works ok without problems, the HDHomeRun also picks up a number of radio channels (e.g. BBC1-4) which I can tune to/receive with the HDHomeRun app but I can’t convince Plex to record from those radio channels. The EPG picks up the Program Guide ok for the radio stations and I can schedule shows but they don’t seem to get recorded. Any clues what I’m doing wrong?
Kind Regards,
Peter
@smurfpower Plex DVR only records TV channels, not radio, so you’re not doing anything wrong there, it’s just not designed to record radio. :slight_smile:
Feature request it is then, thanks :slight_smile: I don’t really get why it won’t record the radio stream though, if it can grab the video+audio streams this should not be hard to do? My suspicion is that it tries to grab the stream but them bails once it doesn’t get any video…
