Unable to upgrade plexmediaserver on Ubuntu 20.04
Server Version#:1.27.0.5897-3940636f2
For some time now I have not been able to install/configure plexmediaserver updates on my linux server. I get the following error during post-install configuration processing:
Setting up plexmediaserver (1.27.0.5897-3940636f2) …
PlexMediaServer install: PlexMediaServer-1.27.0.5897-3940636f2 - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install: Installation Type: Update
PlexMediaServer install: Process Control: systemd
PlexMediaServer install: Plex User: plex
PlexMediaServer install: Plex Group: plex
PlexMediaServer install: Video Group: video
PlexMediaServer install: Metadata Dir: /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install: Temp Directory: /tmp
PlexMediaServer install: Lang Encoding: en_US.UTF-8
PlexMediaServer install: Intel i915 Hardware: Found
PlexMediaServer install: Nvidia GPU card: Not Found
PlexMediaServer install: OpenCL: Installed
PlexMediaServer install: Beignet: Not Installed
PlexMediaServer install: WARNING: The Beignet-OpenCL library, required for hardware transcoding of HDR content, is missing.
PlexMediaServer install: Please install package: ‘beignet-opencl-icd’
PlexMediaServer install: INFO: dpkg will install package ‘beignet-opencl-icd’ automatically
PlexMediaServer install: if available for your host upon successful installation of Plex Media Server.
PlexMediaServer install: Completing final configuration.
Failed to write ‘change’ to ‘/sys/devices/virtual/input/input26/uevent’: Cannot allocate memory
dpkg: error processing package plexmediaserver (–configure):
installed plexmediaserver package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
plexmediaserver
E: Sub-process /usr/bin/dpkg returned an error code (1)
I end up reverting back to an older version 1.25.6 something.
This is on an old Intel NUC with 16G ram and Intel(R) Core™ i3-6100U CPU @ 2.30GHz
This error
has been seen before.
Other places it’s been seen:
  1. When a key remapper has been installed
    Plex fails to install on linux when a key remapper is installed (like Kinto)
  2. when ckb-next has been installed
    Plex Media Server install fails on Ubuntu 20.04 due to ckb-next
This is a DPKG problem with that package and not with Plex.
Reverting PMS version for success is random.
This is centered around dpkg errors with 3rd party keyboard management packages.
Does this also apply to you?
Thank you for the quick response!
I do not see ckb-next, kinto, or xmodmap in my list of installed packages. Are there other packages I should look for?
Thanks!
Marc
Do you have any packages installed which manage / interact with the keyboard?
I’ve also seen this on some of the Pi machines which have an IR remote.
Upgrading after stopping the lircd service worked. Many thanks ChuckPa!
