Unofficial Plex Media Server Installer Package for WD My Passport Wireless (non-Pro model)
@pswygs said:
Newbie here. Thank you for these very detailed instructions. Will these work on a WD Passport (not wireless)? I’m getting a connection error on the web browser, and a ‘command not found’ error in the terminal.
Hi pswygs!
My PMS installer package will only work with the WD My Passport Wireless, as this device contains a small Linux-powered computer which will quite happily run Plex Media Server if configured correctly.
It will not work on a standard WD My Passport device, which is only an external USB storage device. You may however use your My Passport device to store your Plex media library files and access them through a Plex Media Server running on another computer.
Cheers,
Jürg
Hi all!
I’ve updated my unofficial Plex Media Server installer package to PMS v1.2.7.2987.
Cheers,
Jürg
I am seeing the following after trying to launch the Plex Web interface for the first time. This is after the initial login to plex, and on the Plex Server Setup page. (Note: not the server settings page that you can access after the setup completes).
The screen right before the message says " Please wait a moment while Plex starts"
A problem has been detected with a core component of Plex Media Server.
I am running on the latest firmware from WD, and it was the PlexMediaServer-1.2.7.2987-WDMPW.run I downloaded and installed. Any ideas???
Hi all!
I’ve updated my unofficial Plex Media Server installer package to PMS v1.3.0.3059.
Cheers,
Jürg
Hi
I’ve problem to install Plex Media Server on my WD My Passport Wireless. Before I start the steps, I made a complete restore of my device (and factory reset). I successfully followed steps 1 through 5. I installed Putty on my pc but I’m unable to complete step 6 … someone can help me with Putty … I see anything when I enter the command (see attached files)
Denis
@2556denis said:
Hi Denis,
Looking at your screenshot, you seem to be actually logged into your My Passport Wireless. When you enter cd /DataVolume, there won’t be any feedback from your Putty console unless there’s an error. So I think that you actually are already in the root directory of your drive. Typing ls or ls -all should show the contents of your root directory (if you’ve already copied the installer package to your drive, you should see the installer package here as well) and if so, you’re all set to install PMS with my installer package.
Cheers,
Jürg
Hey Mickey,
I really don’t know what this means, but I would simply suggest installing my latest installer package. As my installer package performs a full install when it detects an issue with your installation, this should fix the problem you’re having.
Cheers,
Jürg
Unofficial Plex Media Server installer package for Western Digital My Passport Wireless updated to Plex Media Server v1.3.2.3112.
Enjoy!
Unofficial Plex Media Server installer package for Western Digital My Passport Wireless updated to Plex Media Server v1.3.3.3148.
Enjoy!
Hi, jlempen!
Just stopped by to say BIG THANKS for this wonderful package!
I have successfully installed it on a WD MyPassport Wireless with custom Hackwifidrive FW, so I am happy to report that even the custom-flashed WD MPW work great with your Plex server!
And yes, Transcoding is virtually impossible with WD MPW, due to relatively weak computing power.
Which is a bit of a problem for me, because my original idea was to have a portable media source to stream to Chromecast. It turns out that in order to achieve this, one needs to actually manually recode the videos on a powerful PC into a Chromecast-compatible format, so that they can all work in DirectStream to Chromecast.
Do I get it right that in this case there will be almost no computing load on WD, and I will be able to stream them directly? And is there a way to completely disable any transcoding in Plex server settings?
Hi jlempen,
Great work to get Plex running on the MPW, Kudos to you all that put down so much work to mod things to new hardware.
Experienced the same for my Samsung TV-set with Tizen opsys. before an official Plex app were launched.
Everything running smooth.
But have a couple of questions though …
  1. Seems that I need to continue with the DLNA streaming turned off & SSH+FTP enabled even after the installation to keep Plex server running as it should, am I right ?
  2. Will this procedure (that in 1.) mess up the android app “My Cloud” …? Media don’t show up under the photo, video or music tab anymore. Can though access all media under the all tab in the folder structure in the app & show pics & videos in that way but pic thumb nails are now missing there.
  3. And one more thing … even though I’m a great fan of Plex I just wonder which pros Plex actually have over the app My Cloud when you are on the go with your MPW …
I mean on the go when it’s only you, the MPW & your phone or Tablet (with Plex app + My Cloud installed). Sure you can see/play all media over Plex if you updated the libraries back home at your computer (as you can’t update libraries over the android Plex app.).
But if you use the MPW to backup pics from a camera SD card they goes to the folder “SD Card Imports” & then I need to update that Plex library before I can see the pics & verify that the import were successful before I format the SD card … but I can’t do that over the android Plex app as you recommended that most of the content auto-updating features should be turned off.
The only thing I can think of is to log into Plex through Chrome with http://192.168.60.1:32400/web as I there can start a library scan … but that will take some time if you have tenth of GB in pics.
So … for a media consumer both in my home wifi network, on the go but also a photographer that needs to verify backups of SD cards… which is the best choice Plex or My Cloud ? That if I can’t have both fully functional per bullet 1. & 2.
OK … an update to the previous post.
Apparently it’s possible to turn on DLNA streaming & disable SSH+FTP again after Plex server install & still keep Plex running … were tricked when I tested this the first time as the Plex server sometimes doesn’t startup when you power on the MPW. Restarting the MPW one or two times fix that problem.
What’s not working properly after the Plex install is the android app “My Cloud”, even with DLNA & SSH+FTP put back to how it was before the installation.
That something isn’t as it should are noticeable in the MPW dashboard by the funny media count (doesn’t have 2064 photos on the MPW) & when you hit the button “Rebuild” under media count a error message turns up about Media crawler internal server.
Below is how this affect the android app “My Cloud” …
Is this something that is possible to fix … or is it just to accept it if I want to have a Plex server running on my MPW ?
Furthermore … found a solution to update the Plex libraries on the go over the android Plex app without turning on various auto update alternatives. Installed an unofficial “Library update channel” made by some member which gives you the possibility to update all or just specified libraries … working perfectly :slight_smile:
You find the Library update channel here : https://forums.plex.tv/discussion/comment/1099022/#Comment_1099022
Any chance of an updated installer package? Plex is now at 1.5.2…
Or can you share how to upgrade without using the whole installer package?
Unofficial Plex Media Server installer package for Western Digital My Passport Wireless updated to Plex Media Server v1.5.3.3580.
Enjoy!
Hi all!
I’m sorry it took me so long to update my installer package, I’ve been very busy on other projects.
But today I updated my Plex Media Server on my QNAP NAS and thought that I would create a new installer package for the WD MPW as well. The update to v1.5.3.3580 seems to be running well on my device, so all is well.
I’ve noticed that it may take some time before the PMS gets reachable after a restart. Watching the output of “top”, PMS is actually running and very busy doing something, so that would explain why the interface is not reachable for a couple of minutes.
I’ve also experienced the fact that sometimes PMS won’t start at all on boot and I can’t understand why. But I’ve experienced the same thing on my QNAP NAS as well, so maybe it’s a Plex thing and not particularly related to the PMS install on a WD MPW…
You may download the current release v1.5.3.3580 in the first post of this thread.
If you wish to upgrade your installation yourself before I upload a new release, then it’s actually quite simple. If you know what you’re doing and have basic Linux knowledge, then you only need to download the PMS update for Seagate ARMv7, rename it from *.rbw to *.tar, decompress the file, then decompress the resulting content.tar.gz file, then decompress the resulting content.tar file, then navigate to the resulting opt subfolder, where you’ll find the plexmediaserver folder which contains the PMS installation. Then make a copy of the start.sh file in the Resources subfolder of your working PMS installation on your WD MPW. Then rename the new plexmediaserver folder to Application and overwrite the old Application folder with the new one and overwrite the start.sh file in the new Resources folder with your backup of the start.sh file. Now reboot and you’ll be running the latest release.
I’m sure it’s not worth the trouble to do it manually. Just wait until I upload the latest release of my installer package which will do everything for you.
Well, actually you should be able to turn DLNA streaming (Twonky Server) back on. I turn off Twonky in order to free up as many system resources as possible for Plex Media Server, but I don’t think that Twonky interferes with PMS at all.
And it doesn’t matter if SSH & FTP is turned on or off, this won’t interfere at all with the user experience when using the device, it only allows you to log into your WD MPW through SSH or FTP to change settings or copy data. I would recommend leaving both options turned on.
  1. Will this procedure (that in 1.) mess up the android app “My Cloud” …? Media don’t show up under the photo, video or music tab anymore. Can though access all media under the all tab in the folder structure in the app & show pics & videos in that way but pic thumb nails are now missing there.
Yes, turning off the Twonky Server will most certainly mess up the My Cloud app. If you want to turn Twonky on again (permanently). SSH into your WD MPW and run the following commands:
sudo echo "enabled" > /etc/nas/service_startup/twonky
sudo chmod 775 /etc/nas/service_startup/twonky
sudo chown 1000:share /etc/nas/service_startup/twonky
sudo bash /etc/init.d/S92twonkyserver start
  1. And one more thing … even though I’m a great fan of Plex I just wonder which pros Plex actually have over the app My Cloud when you are on the go with your MPW …
slup, I’m actually starting to ask myself the same question :slight_smile: But I don’t have a definitive answer to that question. I really like the whole Plex ecosystem and I’ve been using Plex for many years now, that’s why I use it on all my devices. But I actually use Kodi and/or LibreELEC with the plexkodiconnect plugin as a media player on all my devices. So maybe one day I’ll decide to drop PMS on the WD MPW and just use the device as a simple media drive for Kodi when I’m on the go…
Cheers,
Jürg
I looked into the files and it does seem simple to accomplish according to your instructions. However, within the existing “Application” folder on my WDMPW, there is a folder named “WDMPW Scripts”. I’m assuming i need to retain that folder within the new “Application” folder to keep everything working correctly?
I have your 1.5.3 working, but I have the installer files for the new 1.6.1 and wanted to experiment doing it manually…
Unofficial Plex Media Server installer package for Western Digital My Passport Wireless updated to Plex Media Server v1.6.1.3722.
Enjoy!
Hey ugdstudios,
The “WDMPW Scripts” folder within the “Application” folder is not necessary for the Plex Server to run correctly on the My Passport Wireless. This folder contains a copy of the various startup scripts needed to make PMS run on the device, as well as an uninstaller script. These scripts are copied to the filesystem during the installation process and are left behind after the installation is complete. No need to retain that folder if you update manually, but it wouldn’t harm to keep it as a backup.
Cheers,
Jürg
Unofficial Plex Media Server installer package for Western Digital My Passport Wireless updated to Plex Media Server v1.7.2.3878.
Enjoy!
Hi! I get a “This XML file does not appear to have any style information associated with it. The document tree is shown below.” message when i try to access the server. I uploadded a screenshot.
