Updating Plex On Raspberry Pi B3+
Im running the plex server on a raspberry Pi. Ive followed this write up: https://www.raspberrypi.org/forums/viewtopic.php?f=36&t=214655&p=1321050#p1321050
though it does not cover updating. How would I go about updating plex on the RPi?
sudo apt-get update
sudo apt-get upgrade
I do not believe that they pull from the plex updates.
Any info on how to update plex server this way would be fantastic
Should I just use this then?
sudo apt-get install plexmediaserver-installer -y
Please read this notice and just forget about this “tutorial”. It’s wrong in many aspects.
Regarding the update: you did install my Debian repository so just update your Debian and PMS with sudo apt update && sudo apt upgrade
http://forums.plex.tv/discussion/320440/important-advice-avoid-any-tutorial-that-mentions-the-etc-default-plexmediaserver-prev-file
How is it wrong? This is how I figured out how to make it work.
wget -O - https://dev2day.de/pms/dev2day-pms.gpg.key | sudo apt-key add -
echo “deb https://dev2day.de/pms/ jessie main” | sudo tee /etc/apt/sources.list.d/pms.list
sudo apt-get update
This is what I have done previoussly. are these the repository you were talking about?
It’s described in the discussed thread. E.g. the instructions provided to tell Plex to use user pi are completely wrong. The instructions do NOT work at all. Plex is still using user plex. So you will have permission issues sooner or later.
https://dev2day.de/pms/ is my repository. You have told your local package manager apt to access my repo by creating the file /etc/apt/sources.list.d/pms.list.
Now when you use apt to update your Debian (that’s what Raspbian essentially is) apt will also check my repository for new Plex updates and install them.
Please read the debian manual to learn more about apt.
https://www.debian.org/doc/manuals/debian-faq/ch-pkgtools.en.html
I apologize. I was confused because you said it would not work and It’s been working for 3-4 days now. Either way, I’ll double check my configuration with your repository when I get home tonight.
Thank you! I wasnt super sure if the apt-get update would work or not with the way I had it set up.
You have any idea how to make streaming buffer less? Is it a plex server issue or are the movies too high of quality to stream from a pi?
Please read our official setup instructions. Especially the “Manage Expectations” section :wink:
http://forums.plex.tv/discussion/309553/plex-media-server-for-armhf-and-arm64-using-debian-or-ubuntu
And please read up on the terms “Direct Play” and “Direct Stream”. With an RPi your Plex clients always have to use one of these two playback modes. The RPi does not have the power to really support live Video transcoding.
https://support.plex.tv/articles/200250387-streaming-media-direct-play-and-direct-stream/
so direct play is for compatable media, so I would have to convert all my .MKV to .MP4 and it will buffer less right? am I reading that correctly?
No, not at all :neutral: Please read the second document again. E.g.
Media can be Direct Played on a device if the source media is compatible with the client’s playback capabilities, meaning that the source media:
Is stored in a compatible file container
That’s the difference between mkv and mp4 and mkv is fine for Direct Stream. However, much more important are the next points.
Is encoded in a compatible bitrate
Is encoded with compatible codecs
Is a compatible resolution
There are support documents for most supported clients telling you exactly what is supported. However, you also have to configure the clients appropriately, e.g. set the quality options to “Original” or “Maximum”.
Here is for example the document for the PS4. Just use the search function on this page to look for information for other clients.
https://support.plex.tv/articles/204377253-what-media-formats-are-supported/
okok, so the following:
The Plex for PlayStation app does not currently support Direct Playing of MKV container videos. If the audio and video streams in the file are otherwise compatible, it will be Direct Streamed without losing any quality.
Is fine because my movies are like TheBountyHunter.mkv so all the movie and media are in the same file so apparently that is good!
So I need to check the bitrate codecs and resolution? What are the reccomended specs for bitrate codec and res? And if Mine are not to spec how would I change them?
I may not be understanding the whole problem here.
What about using this Handbrake to eliminate transcoding?
Tell us about the video and audio codecs in your mkvs and we can tell you if re-encoding the whole library is a good idea. E.g. if the videos are encoded with h264 then everything is fine as it is and you just have to tweak the Plex client settings.
How would I find something like that?
Please read the Plex support documents. It’s all there :wink:
  1. Bad Teacher
    Codec H264
    Bitrate 2158 kbps
    Bit Depth 8
    Chroma Location left
    Chroma Subsampling 4:2:0
    Color Primaries bt709
    Color Range tv
    Color Space bt709
    Frame Rate 23.976 fps
    Height 1040
    Level 4.1
    Profile high
    Ref Frames 4
    Stream Identifier 1
    Width 1920
    Codec AAC
    Channels Stereo
    Bitrate 97 kbps
    Language English
    Audio Channel Layout stereo
    Profile lc
    Sampling Rate 44100 Hz
    Stream Identifier 2
  2. The Bounty Hunter
    Codec H264
    Bitrate 1904 kbps
    Language English
    Bit Depth 8
    Height 816
    Level 4.0
    Profile high
    Ref Frames 5
    Stream Identifier 1
    Width 1920
    Codec AAC
    Channels Stereo
    Bitrate 102 kbps
    Profile lc
    Stream Identifier 2
  3. Ex Machina
    Codec H264
    Bitrate 2063 kbps
    Bit Depth 8
    Color Range tv
    Color Space bt709
    Height 808
    Level 4.1
    Profile high
    Ref Frames 4
    Stream Identifier 1
    Width 1920
    Codec AAC
    Channels Stereo
    Bitrate 98 kbps
    Language English
    Profile lc
    Sampling Rate 48000 Hz
    Stream Identifier 2
  4. Minority Report
    Codec MPEG2VIDEO
    Bitrate 6193 kbps
    Language English
    Anamorphic true
    Bit Depth 8
    Color Range tv
    Frame Rate 29.97 fps
    Height 480
    Level 8
    Pixel Aspect Ratio 8:9
    Profile main
    Ref Frames 1
    Scan Type interlaced
    Width 720
    Codec AC3
    Channels 5.1
    Bitrate 448 kbps
    Language English
    Audio Channel Layout 5.1(side)
    Title Surround 5.1
    Codec DCA
    Channels 5.1
    Language English
    Profile dts
    Title Surround 5.1
    Codec AC3
    Channels 5.1
    Bitrate 384 kbps
    Language Français
    Title Surround 5.1
    Codec VOBSUB
    Language English
    Codec VOBSUB
    Language Español
    Codec VOBSUB
    Language Français
Hope this helps. These are 4 randomly selected movies on the server. Let me know if this is helpful or if you need something else.
The first three movies are in a perfect format: h264 video and aac stereo audio, no subtitles. Nearly any client should be able to play these videos without transcoding. Do you experience buffering while watching any of these videos? Please make sure to select “Original” or “Maximum” quality in the client and tell us about your client.
I will test this out tonight, some movies buffer and some dont, I just thought that it was my internet that was slowing down but I will pay more attention to what buffers and what does not
and what do you mean tell us about the client?
I know for a fact that Horrible Bosses buffered like every 10-15 min, and the wheel was spinning for another 5-10 min before it wuld start playing again
Horrible Bosses:
Codec H264
Bitrate 2017 kbps
Language English
Bit Depth 8
Color Range tv
Color Space bt709
Height 800
Level 4.1
Profile high
Ref Frames 4
Stream Identifier 1
Width 1920
Codec AAC
Channels Stereo
Bitrate 102 kbps
Language English
Profile lc
Stream Identifier 2
What do you use to watch your movies? :wink: Chromecast, FireTV, Android, iOS, Samsung TV, …
Horrible Bosses:
Codec H264
Bitrate 2017 kbps
Codec AAC
Channels Stereo
Bitrate 102 kbps
The format of this movie is a piece of cake for any client. Just set the client to “Original” quality.
