Hi!
I tried to install the Storage of RasPlex on USB drive and not the SD Card.
I come from OpenELEC and was using it there without any problems.
Why I want it on USB? At OpenELEC it is snappier.
When I try to run RasPlex from USB I get the following error: Could not mount UUID=…
So has anyone of you running RasPlex with this setup? Or is this not supported?
Thanks in advance!
Best Regards
Hi!
When I try to run RasPlex from USB I get the following error: Could not mount UUID=....
Thanks in advance!
Best Regards
If you are running the latest version of Rasplex (0.4.0-rc4) there is no benefit in running from a USB, just stick to a Class 10 SD card installation.
Regards
Ok, got it running now without USB drive and speed is good!
Thanks ;)
