using pyplex as a headless pled audio-only client?
I've just stumbled upon pyplex: https://github.com/dalehamel/pyplex
Anyone tried to use this as a audio-only client? Would be great to use this in addition to rasplex just for connecting to the stereo and control my music via iOS remote or Plex web app.
Regards,
Matthias
Regards,
Matthias
Yep, two years old and I believe now defunct (may be wrong), you can use Rasplex headless just for music connected to amp and controlled by Android or iOS tablet or phone. What you couldn't do is run Rasplex and Pyplex on the same Pi.
Regards
@igno2k said:
I’ve just stumbled upon pyplex: GitHub - dalehamel/pyplex: An interfaceless PLEX client for Raspberry Pi, designed to be used with an iOS remote.
Regards,
Matthias
that is a great idea, anyone found a way to run this for audio only ? plex should consider developing a feature similar to sonos, link “AudioPlex” streamer
@igno2k
@hidea
Rasplex 0.7.0 can be used as a headless music system see post on Dual Audio http://forums.plex.tv/discussion/174494/rasplex-dual-audio-only-for-0-7-0#latest
I use a couple, one headless connected to a stereo amp and one headless connected to a Bluetooth transmitter for Bluetooth headphones.
Regards
well it’s not exactly what i’m looking for, i was searching for an headless client, not the rasplex distrib, because i have other stufff running on my raspberry pi that cannot be used on rasplex. Do you have any hints on how to install plexpy or another client ?
Googled is your friend, there are numerous audio players out there that run on Raspbian, try the Raspberry Pi forums.
Regarding Pyplex see my first response to your original post.
This is after all the Rasplex client forum, if your not interested in Rasplex why did you post?
Regards
well i did post it here because i just wanted to know how to run pyplex, i mean it is a great idea
as a matter of fact i just wanted to check if anyone have tried running it. The thing is i wish i had a plex audio client so that i can stream my plex music natively to this client, i’m not a big fan of other audio players because they are not integrated with plex
thanks for your quick feedback
For information, i just installled pyplex and run it aand i have nothing appearing as plex client, here is the log, it indicates that it cannot find any server, any help on how to enable the server lookup in pyplex or PMS ?
2015-09-10 19:14:12,523 INFO PyPlex: Starting up...
2015-09-10 19:14:12,534 INFO AvahiLookUp: Looking for _plexmediasvr._tcp type Avahi shares
2015-09-10 19:14:13,555 INFO AvahiLookUp: Found 0 server(s)
2015-09-10 19:14:13,556 INFO PyPlex: Setting up listeners
2015-09-10 19:14:13,589 INFO ZeroconfService: 'Published avahi Service with name 'radxa PyPlex' on port 3000 with text '['machineIdentifier=radxa', 'version=2.0']'
2015-09-10 19:14:13,592 INFO xbmcCommands: Initated xbmcCommands
2015-09-10 19:14:13,595 INFO udplistener: Started UDP listener
2015-09-10 19:14:13,600 INFO httplistener: HTTP Init done
2015-09-10 19:14:13,624 INFO PyPlex: Running PyPlex
2015-09-10 19:14:13,633 INFO httplistener: Started HTTP listener
